Dennisgb
Posted: Wed Feb 06, 2008 12:05 pm |
| Advanced Poster |
Joined: Mon Jun 18, 2007 1:19 pm Posts: 355 Location: Minnesota USA Been Liked: 2 times
ericlater @ Wed Feb 06, 2008 5:02 pm wrote: OMG, my last post was a bit confusing. More specifically, only the problem with the microsoft sounds still exists. In other words, all of the chimes and related that spring up by themselves, as when one restarts a computer, still blare out whenever they come into play. Anyone have any suggestions?
Go into settings under control panel, sounds, you can adjust volume or just turn them all off.
Dennisgb
Posted: Wed Feb 06, 2008 2:51 pm |
| Advanced Poster |
ericlater @ Wed Feb 06, 2008 1:34 pm wrote: I didn't care about improving the sound on the desktop and was skeptical that the new card would solve the problem. Since it was only asking $40 to install it, I figured it was worth a try.
Well, it didn't solve my problem (which still exists), but I learned from that experience how good the sound card is on the laptop since I compared the laptop to the "new and improved" desktop. Thought the sound on the desktop has be greatly enhanced, the sound on the laptop is still better!!
The first thing I have to say about this, is that you can't get a quality sound card for $40 installed. That being said, I don't see how this is a real comparison. So, your laptop sounds better than a cheap desktop sound card?
I have tested a few high end laptops, and there are plenty of tests on the web, and none of them have decent sound cards. There are issues with space in a laptop, and the first thing they leave out are the filters needed to reduce the noise that is inherent in having a bunch of hot electronic parts and a number of whiring mechanical devices within inches of each other packed into that tiny space. Add to that the issue of ground loops, and it is a disaster waiting to happen.
If you take the time to compare your laptop sound to a desktop with a quality sound card, you will find that your laptop is lacking. Not only are laptop sound cards lacking in design, but they do not have pre-amps, clean flat frequency response, and on and on. They are the bare bones budget uglies of sound.
To some this may be totally subjective, and granted if you have bad hearing, are tone deaf or haven't heard a system with a quality sound card and quality sound system, then certainly, a laptop internal sound card is just fine.
But, consider that you are overdriving your sound system (which in turn increases the chance of noise), and maybe with a decent sound card you could get that extra bass punch and little bit more power at the end of the night, without having to buy a new amp and speakers.
Seriously, get a decent sound card. You will be surprised at the difference.
ericlater
Posted: Wed Feb 06, 2008 7:14 pm |
Of course, you must be right, Dennis. I have no idea how my laptop sounds. I best rely upon the opinion of someone who has never heard my system to let me know what it must be lacking?
The one thing I do know, the sound my rig produces does not change as I switch back and forth during my show between my deck (Dvd, MP3, CDG, etc player) and my laptop. I guess there's something wrong with by deck, as well?
As to my $40 sound card; it isn't a sound card that retails for $40! In order to placate my disappointment with their work, the geeks sold me the card and installed it for $40. They quoted the retail value of the card at much more than that. But, so what?
Dr Fred
Posted: Wed Feb 06, 2008 9:40 pm |
Joined: Wed Aug 22, 2007 5:22 pm Posts: 1128 Location: Athens, GA Been Liked: 4 times
I bought a soundblaster external sound card for my laptop. I got the sound to go through it fine and aparently with no problem but when combined with compuhost and an external hard drive the USB ports were apparently being overtaxed.
The net result was that the sound ended up a bit slower, and by the end of a 5 minute song the words were out of sync with the beat of the music by about half a second.
Sure it was not much but enough to annoy the singers. I switched to not using a sound card, and sure it may be worse sound but I cant tell the difference.
That is the major point with a lot of musical information and equipment quality. It may be "worse" than another way but if the difference is too small for a person to detect why bother to fuss about it.
That said I think the sound card on my laptop is better than some others especially on older laptops.
sidewinder
Posted: Wed Feb 06, 2008 9:46 pm |
| Non-Member |
Joined: Sun Dec 16, 2007 8:49 pm Posts: 1250 Been Liked: 0 time
Your laptop grounding problem will not be fixed by a 2 prong adapter. A home theater installer suggested i do that when i was setting up a bar he wired for sound and video. I had a hum. He told me to lift the ground on the amplifier. Wrong answer. That made it real bad. Being a good KJ that plans for everything, i have a bag of tricks i carry around.
The fix to your problem is a video isolator. You have an audio one from Radio Shack. That just isolates the music. Now isolate the video.
ericlater
Posted: Thu Feb 07, 2008 3:59 am |
Does it make a difference to know that the hum occurs without any programs being opened? In other words, as soon as the laptop is turned on, it hums!
RLC
Posted: Thu Feb 07, 2008 5:17 am |
ericlater @ Wed Feb 06, 2008 9:13 am wrote: Now that I've had some time to play around with the ground loop isolator, I've found that it has not helped in eliminating the hum caused by the laptop.
The only two solution I have found so far that work are: - Plug the laptop into an outlet by itself - Use a 3prong>2prong adaptor between the laptop and the power source
And much to my surprise, the little bit of a hum I have coming from my mixer (at volumes levels I don't use) worsened with the isolator attached. Go figure that?
So, while I am sure the isolator at $17.00 will come in handy someday, I got three adaptors at the dollar store for $1.00!!
Although it is a little pricey this item will get rid of the laptop hum and still protect your laptop (by maintaining the ground)
http://www.musiciansfriend.com/product/ ... sku=150452
Dennisgb
Posted: Thu Feb 07, 2008 5:46 am |
| Advanced Poster |
ericlater @ Thu Feb 07, 2008 12:14 am wrote: Of course, you must be right, Dennis. I have no idea how my laptop sounds. I best rely upon the opinion of someone who has never heard my system to let me know what it must be lacking?
Why are you seeking opinions, when you already have made up your mind?
If you do a little research, you may find that what I have told you is correct.
There are other factors that enter into this, the most important of which is the actual sound system you are playing through.
Since your happy, that's all that really matters.
Good luck.
ericlater
Posted: Thu Feb 07, 2008 9:58 am |
Dennis,
I don't recall asking for any opinions regarding my rig. I made a posting that stated, in effect, how lucky I feel I was having ended up with my rig, while not having had all of the specs necessary to make the best decision.
RLS,
By golly, I think you've got it!?!? I'm gonna give it a try; $59 isn't that steep if it really works. I wonder if I should connect the gadget directly to the PC or will it work at the receptacle end of the power, as well? Anyone know?
RLC
Posted: Thu Feb 07, 2008 3:01 pm |
I just plug the laptop power into it and then it into the power strip with everything else. Lonman is the person who directed me to this item, I too was using the 3 prong to 2 prong adapter, which did get rid of the hum, but I wanted to maintain the grounding for my laptop so I opted for this item.
sidewinder
Posted: Fri Feb 08, 2008 12:50 am |
| Non-Member |
Does it hum with the TVs hooked up and the amplifier on?
XooNooX
Posted: Mon Feb 11, 2008 12:56 am |
Joined: Sun Jan 27, 2008 11:56 pm Posts: 19 Been Liked: 0 time
Hm... it seems that this 2 prong adapter can reduce or eliminate the "humm" in the speakers - but you may pay for this with a high price, which is your life.
There is a good reason why you have three pins. If any electrical part in your system is blank and you touch a metal part (e.g. on your laptop), the power is going through your body instead the ground pin.
At least here in Europe, using such an adapter would be strictly forbidden - with all consequences you may have to face if there is a problem.
Wolfgang
Posted: Mon Feb 11, 2008 1:48 am |
RLC @ Thu Feb 07, 2008 3:01 pm wrote: I just plug the laptop power into it and then it into the power strip with everything else. Lonman is the person who directed me to this item, I too was using the 3 prong to 2 prong adapter, which did get rid of the hum, but I wanted to maintain the grounding for my laptop so I opted for this item. Exactly, that was a sound engineers sidestep trick for years for a TEMPORARY fix, but you do no want to permanantly have the ground lifted & the Ebtech is the solution to any ground loop (hum) without doing any dangerous ground eliminating.
sidewinder
Posted: Mon Feb 11, 2008 1:59 am |
| Non-Member |
Video Ground Loop Isolator
MCM Part #: 33-6926
This thing is 2.5-3 inches long. RCA ends.
sidewinder
Posted: Mon Feb 11, 2008 1:46 pm |
| Non-Member |
I just hooked up at a brand new bar. New building and all, 6 months old. All new HDTVs that need a special adapter box to change the signal to HDTV. And i had to put in the audio and video isolators to STOP all the hum. I will just leave them permanently hooked into my system and i won't have to worry anymore about any place.
It also stopped the ghost video interference on the TVS that kept rolling from top to bottom on the screen.
ericlater
Posted: Sun Feb 17, 2008 7:50 am |
I still seeking advice on where along the line it is best to plug that ($59) doohickey in?
I'd prefer, if possible, to plug it in at the receptacle and then plug the power strip into the filter? Will that work?
RLC
Posted: Sun Feb 17, 2008 8:30 am |
You could try that, but first I would plug your laptops power supply into the filter and then plug the filter into your power strip. Turn on laptop (of course with the system fired up) and see if the hum is gone--it should be.
sidewinder
Posted: Sun Feb 17, 2008 2:20 pm |
| Non-Member |
I would not mess with lifting the ground on a computer. Isolate the video & audio signal. It has no effect on the ground. What are you going to do if the computer takes a surge? Or there is a bar electrical circuit problem? You will have removed any last little bit of protection without the ground.
RLC
Posted: Sun Feb 17, 2008 2:30 pm |
sidewinder @ Sun Feb 17, 2008 4:20 pm wrote: I would not mess with lifting the ground on a computer. Isolate the video & audio signal. It has no effect on the ground. What are you going to do if the computer takes a surge? Or there is a bar electrical circuit problem? You will have removed any last little bit of protection without the ground.
Do you even know what we are talking about here? Read the thread.
Posted: Sun Feb 17, 2008 2:34 pm |
 , eric here is the link to the ebtech products. The first one is the ground lifter! SAFE to use on any piece of gear.
http://www.musiciansfriend.com/navigation?q=ebtech
Users browsing this forum: No registered users and 2580 guests |
