KARAOKE SCENE MAGAZINE ONLINE! - digital CB on ebay Public Forums Karaoke Discussions Karaoke Legalities & Piracy, etc... Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Oct 23, 2026 12:24 am
 Post subject: digital CB on ebay
PostPosted: Sun Dec 11, 2016 6:07 am
Images: 19
Been Liked: 32 times
On ebay looking for a few disc and ran across this, would this be legal to use ?
http://www.ebay.com/itm/10-CHARTBUSTER- ... Swn1RXI5Ka
I only do private parties, and you're not invited
 Post subject: Re: digital CB on ebay
PostPosted: Sun Dec 11, 2016 6:44 am
yes they should be, chartbuster used to release their products on sd card all the time
PostPosted: Sun Dec 11, 2016 7:22 am
Images: 19
so I could swap them over to a hard drive without any worries ?
PostPosted: Sun Dec 11, 2016 7:45 am
8) I'm a little confused is it the player and the card only, or are the SCDG's also included? The reason I ask is there is a program from Roxbox that converts SCDG's so that the background vocals are eliminated and the track can be transferred to a PC format.
Last edited by The Lone Ranger on Sun Dec 11, 2016 7:49 am, edited 1 time in total.
PostPosted: Sun Dec 11, 2016 7:48 am
Images: 19
the way I read it , it was only the SD card
PostPosted: Sun Dec 11, 2016 7:54 am
8) If the card carries the same weight as the SCDG's all fine and good. Most companies that used to sell pre- loaded players have stopped offering that product due to copyright problems. My only concern is that if someone should check you out you would only have the card and not have the cd's, I don't know if that will fly as far as a 1 to 1 ratio standard.
PostPosted: Sun Dec 11, 2016 8:23 am
The legitimacy of SCDG's has always been questionable, but the SD card is w/o a doubt legal.... unless they are bootlegged copies. :? I would also bet they are not bootlegged coming from this vendor.
PostPosted: Sun Dec 11, 2016 8:28 am
The legitimacy of SCDG's has always been questionable, but the SD cards is w/o doubt legal.... unless they are bootlegged copies. :?
8) The same can be said for SCDG's unless they are bootlegged copies. If the SCDG's are bootlegged it is not PEP's duty to go after the host's but the trademark owner who happens to be CAVS for the SCDG product. Oh by the way I talked with CAVS a couple of years ago and at that time they had no plans to go after hosts using their product.
PostPosted: Sun Dec 11, 2016 9:20 am
Images: 19
why would you need a 1-1 ratio if it was issued in digital format ?
PostPosted: Sun Dec 11, 2016 9:31 am
Images: 19
so unless you convert these from their current form they won't play on a normal Karaoke software player ?
PostPosted: Sun Dec 11, 2016 11:19 am
8) That's why you need the Roxbox SCDG converter program, so that the SCDG can be used on the PC Format, also to remove the lead vocal that is present on the SCDG's discs I don't know about the card, never used one.
PostPosted: Sun Dec 11, 2016 11:21 am
8) I guess you wouldn't if it is a CAVS product and PEP has no standing to sue on the CAVS trademark.
PostPosted: Sun Dec 11, 2016 2:01 pm
You do not need to convert anything, they are not scdg discs in this listing. If Loneranger had bothered to look at the listing you linked to it is totally clear that these are already in mp3g format on sd cards (not scdg) and will play from any computer with any karaoke software capable of playing mp3g (which is all of them I would guess).
You can move them right onto your hardrive as they are, you do not need any conversion software.
All is good.
Edit: You will need a sd reader on your computer, if you don't have one you can get a sd to usb reader such as this for under $10 https://www.amazon.com/Anker-Reader-RS- ... rd+adapter
PostPosted: Sun Dec 11, 2016 3:47 pm
8) Like I said my experience is with SCDG's not the card format. Since the source of the material is SCDG's then they would come under the CAVS Trademark, and not be subject to legal action by PEP.
PostPosted: Mon Dec 12, 2016 1:11 am
sorry Lone, those are not SCDG cases, they are SD card cases. there are no SCDG's in that auction.
PostPosted: Mon Dec 12, 2016 4:45 am
Images: 19
thanks for the info, gonna grab a set.
Users browsing this forum: No registered users and 427 guests
