_________________ To be fortunate enough to derive an income from a source as fulfilling as karaoke music has got to be as close to heaven as we can get here on earth!
Joined: Thu Aug 05, 2010 1:40 pm Posts: 1052 Images:1 Been Liked:204 times
What format are the files on the SD set? I have a few dozen of the USB sticks and the files are low-res video .avi files. I won't use those at a show because the format does not scale consistently from monitor to monitor.
Joined: Thu Aug 12, 2010 6:24 pm Posts: 5108 Location: Phoenix Az Been Liked:1280 times
i saw the original picture you posted and it looked like the cards had the CB label over another label that was white. i don't know if they all did that since i don't own any, but someone else may. it would be enough with me not knowing for sure to check.
Users browsing this forum: No registered users and 414 guests
