KARAOKE SCENE MAGAZINE ONLINE! - Now, A Little Logic. ( Sadly Missing These Days ) Public Forums Karaoke Discussions Karaoke Legalities & Piracy, etc... Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Oct 23, 2026 4:28 pm
PostPosted: Mon Mar 16, 2015 5:40 am
In logic and critical thinking, a slippery slope is a logical device, but it is usually known under its fallacious form, in which a person asserts that some event must inevitably follow from another without any rational argument or demonstrable mechanism for the inevitability of the event in question.
A slippery slope argument states that a relatively small first step leads to a chain of related events culminating in some significant effect, much like an object given a small push over the edge of a slope sliding all the way to the bottom.
The strength of such an argument depends on the warrant, i.e. whether or not one can demonstrate a process that leads to the significant effect. This type of argument is sometimes used as a form of fear mongering, in which the probable consequences of a given action are exaggerated in an attempt to scare the reader.
However, if an argument uses valid reasoning, it would not identify by the slippery-slope approach.
The fallacious sense of "slippery slope" is often used synonymously with continuum fallacy, in that it ignores the possibility of middle ground and assumes a discrete transition from category A to category B.
Modern usage avoids the fallacy by acknowledging the possibility of this middle ground.
Y0re mileage may vary.
PostPosted: Mon Mar 16, 2015 5:55 am
Would ACA fall into that category? It is built on some rather unproven premises and assumptions.
PostPosted: Mon Mar 16, 2015 8:12 am
Did you write that JD? It sounds like something a Politician or a Lawyer would say. :lol:
PostPosted: Mon Mar 16, 2015 8:17 am
Well (JD) does stand for Juris Doctor :)
PostPosted: Mon Mar 16, 2015 10:39 am
And here I thought JD stood for Just Delirious.
PostPosted: Mon Mar 16, 2015 12:07 pm
Yes indeed as in “Doctor of Jurisprudence” but then again it could also be “Jack Daniel’s” :hi5: (kidding, jd).
PostPosted: Tue Mar 17, 2015 8:07 am
While I'm not a Lawyer, I do watch Judge Judy on TV.. :mrgreen:
PostPosted: Wed Apr 01, 2015 5:13 am
Users browsing this forum: No registered users and 432 guests
