KARAOKE SCENE MAGAZINE ONLINE! - Analog Mixers for a Computer Recording Setup Administrative Comments, Suggestions & Questions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Fri Oct 23, 2026 2:17 pm
PostPosted: Tue Jan 25, 2005 2:00 pm
Types of Analog Mixers for a Computer Recording Setup
The Main question: How many tracks need to be recorded simultaneously (i.e., at the same time)? You need as many inputs on your soundcard or audio interface to cover that first off. Then you need that many independent outputs (sub outs) on your mixer to mate with these inputs. These independent outputs are called "sub outs" or the "alt 3-4 bus". These are different terms for the same thing. You can also use direct outs if the mixer has them, if you don't mind re-patching the gear you want to record into it's path.
8 Bus (ideally for 8x8 audio interfaces, standalone multitrack recorders)
4 Bus (ideally for 4x4 audio interfaces)
2+2 Bus (Ideally for 2x2 stereo soundcards)
Stereo Only (Ideal for those only connecting mics and guitars for tracking though workarounds are possible)
Preamp only (for those going mixerless on a budget)
Courtesy of TweakHeadz (http://www.tweakheadz.com)
Users browsing this forum: No registered users and 186 guests
