Phil Why ?
https://ksmo.us/forums/viewtopic.php?f=13&t=14813
Author:  Karaoke Kelley [ Fri Oct 17, 2008 11:31 am ]
Post subject:  Phil Why ?
Why cant I seem to upload a profile pic to Singers Showcase ? I can send you the pic & maybe you can figure it out. I know Im doing everything the same as Ive always dont it..dont know whats different now. This site is so crazy these days !
Author:  Phill Cross [ Wed Oct 29, 2008 10:00 am ]
Post subject:  Re: Phil Why ?
I apologize - I don't check in very often - stuff has me busy...
Anyway yeah go ahead and send to me I'll look into it -
I don't know what is going on here - I try to make things simple but somehow they getting screwed up?? Arrgg :roll:
:vomit:
Hopefully you have my email: webmaster at karaokescene dot com
Author:  Flipper [ Thu Nov 13, 2008 11:37 am ]
Phil I'm having the same problem as Kelly
I know I have the right file type, size etc as I have posted many pics here and I made sure that I have not used up my allocated space on the system.
In the filename field it is highlighted bright white, it normally is dark gray. When I hit browse and select the file and hit open it does not accept the file and does not give any message as to why, the filename never appears in the field.
I'm thinking you might try loading a photo yourself and see if you can get it to cooperate.
Scott
Author:  Flipper [ Thu Nov 13, 2008 11:39 am ]
that's wierd I went out of this thread and back into it and the pic has posted in my reply yet it did not register as the system taking it. ????????
Author:  Flipper [ Fri Nov 14, 2008 7:46 am ]
Wow Thanks for the info. That's too bad....oh well sometimes folks just lose interest.
I was able to post the pics but it never showed that the file was accepted I just hit add and found that they were added anyway.
I can work with that.
