| Singer's monitor https://ksmo.us/forums/viewtopic.php?f=1&t=9925 |
| Author: | Skyz [ Wed May 30, 2007 11:05 pm ] |
| Post subject: | Singer's monitor |
I am considering going to a singer's monitor. My reason is, I'm now playing larger rooms and may want to switch to stereo... Because my amp will only do 8 ohms per channel, how can I only connect a Peavey Impulse II as it is rated at 16 ohms? |
| Author: | Lonman [ Thu May 31, 2007 1:10 am ] |
| Post subject: | Re: Singer's monitor |
2 16 ohm speakers hooked up to the same channel will yield 8 ohms - if you are only hooking 1 16 ohm speaker up, the amp may not be powerful enough to push them efficiently, the more ohms, the less power the amp pushes & the speaker receives. What does the rest of your system consist of to begin with? Makes, models, amps, speakers, processors? As far as running stereo, really is no need - especially in larger rooms. The bigger the room, the less need for stereo. |
