KARAOKE SCENE MAGAZINE ONLINE! - Singer's monitor Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 8:52 am
 Post subject: Singer's monitor
PostPosted: Wed May 30, 2007 11:05 pm
I am considering going to a singer's monitor. My reason is, I'm now playing larger rooms and may want to switch to stereo... Because my amp will only do 8 ohms per channel, how can I only connect a Peavey Impulse II as it is rated at 16 ohms?
 Post subject: Re: Singer's monitor
PostPosted: Thu May 31, 2007 1:10 am
2 16 ohm speakers hooked up to the same channel will yield 8 ohms - if you are only hooking 1 16 ohm speaker up, the amp may not be powerful enough to push them efficiently, the more ohms, the less power the amp pushes & the speaker receives.   What does the rest of your system consist of to begin with?  Makes, models, amps, speakers, processors?
As far as running stereo, really is no need - especially in larger rooms.  The bigger the room, the less need for stereo.
Users browsing this forum: No registered users and 3015 guests
