Which Is A Better Line Out Source
https://ksmo.us/forums/viewtopic.php?f=1&t=9825
Author:  karaoke for food..... [ Tue May 15, 2007 4:01 pm ]
Post subject:  Which Is A Better Line Out Source
For a laptop Hoster System, is firewire, or USB a better way to get audio to your mixer? Talking karaoke shows here, not for home use. And how do you set yours up, and what interface are you using?
Author:  Lonman [ Tue May 15, 2007 4:13 pm ]
Post subject:  Re: Which Is A Better Line Out Source
I don't use a laptop, but I did get a rather nice M-Audio internal sound card for my PC.  192 Audiophile.
Author:  karyoker [ Tue May 15, 2007 4:31 pm ]
If you have a preamp control on your mixer to attenuate a little  you can also use the head phone out.
Author:  knightshow [ Wed May 16, 2007 5:17 am ]
I personally use a USB out for a Soundblaster MP3+ Device from Creative... but they're not made anymore. This was a direct RCA connection which was easy to hook into a mixer.
I've looked and looked for other alternatives. I'm not happy with the sound from a basic sound card (1/8" out), but that doesn't mean that there are good ones out there, such as Lonnie's suggestion.
For the average Laptop user, I don't know what to suggest anymore, now that Creative has discontinued this sucker. I ended up buying two off ebay... but I don't see them on there very often!
Author:  jamkaraoke [ Wed May 16, 2007 7:53 am ]
I use on my show laptop an extrenal USB pro sound card from EGO SYSTEMS
a GIGA PORT
http://www.floridamusicco.com/proddetai ... portag.htm
Author:  knightshow [ Wed May 16, 2007 1:41 pm ]
http://www.floridamusicco.com/proddetail~prod~ua1ex.htm the Edirol UA1EX looks spec wise like the Soundblaster option I use!
Author:  Lshiny [ Wed May 30, 2007 2:15 pm ]
I 've not used it myself, but this has been recomended to me.
[/url]http://www.musiciansfriend.com/product/Behringer-UCONTROL-UCA202-USBAudio-Interface?sku=702540&src=00633
Author:  MorganLeFey [ Wed May 30, 2007 3:39 pm ]
http://www.trademe.co.nz/Computers/Comp ... 141441.htm
this is what I use, its cheap unobtrusive and does the job well. I too have a sb external but since I picked up this so cheaply I dont bother taking the more expensive SB to gigs
Author:  DannyG2006 [ Wed May 30, 2007 5:33 pm ]
just got one myself.  I'm chompin at the bit to try it out.
http://www.musiciansfriend.com/product/ ... &src=00633
Author:  karaoke for food..... [ Thu May 31, 2007 12:30 pm ]
Thanks for all the suggestions ...i will be ordering one of these. The price seems very reasonable. Thanks for the help
Author:  eben [ Thu May 31, 2007 10:29 pm ]
Back to your original question, I would have to say firewire rather than USB if you want consistent data tranfer. Firewire has a protocol that maintains steady stream of data over the bus. This means each device has a time period in which to transfer data and these time period is fixed. This is meant for something like video frames so that the bus does not drop any frames during the transfer. USB is asynchromous so if you have many devices, the bandwidth share between the devices are not equal. It's not likely but in case of lot of data being transferred on the bus, Firewire will give each device time to transfer data so you won't have dropped data.
Author:  Odie [ Sat Jun 02, 2007 4:55 pm ]
Ben, you are correct about Firewire being more consistent with data transfer from what I've read.  But do you happen to know if USB 2.0 is better at data transfer then USB 1.2?
Author:  Odie [ Sat Jun 02, 2007 4:58 pm ]
Somebody please post a review of this Behringer USB audio interface after they've tried it out.  I'm curious about it myself.
Author:  eben [ Sun Jun 03, 2007 9:21 am ]
Odie, USB 2.0 still does not offer isochronous tranfer function, which is why firewire transfers data at the same time window, providing consistent data transfer. However, USB 2.0 does offer faster transfer so it's less likely that the data will encounter interruptions than USB 1.1. I am not familiar with USB version 1.2, the official version prior to 2.0 was 1.1.
Author:  Odie [ Sun Jun 03, 2007 11:12 am ]
Thanks Ben, I meant USB 1.1.  I just got my 1's and 2's mixed up! Nevermind...  LOL
