KARAOKE SCENE MAGAZINE ONLINE! - crown amp Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 8:06 am
 Post subject: crown amp
PostPosted: Fri May 04, 2007 7:18 am
I have a crown ce2000 been using about 4 years great amp..last night 1 channel just drops out..I put a lot of volume into that channel it pops back on and ran for a couple hours then did it agian.... any ideas...thanks
 Post subject: Re: crown amp
PostPosted: Fri May 04, 2007 7:36 am
I had a similiar problem a few years ago -  ALL of a sudden one side of my set up just goes silent ?      Same thing - boosted the volume and all of a sudden when the bass kicked in --started working again...on and off all night like that.........
In my case IT WASN'T THE POWER AMP BUT LOOSE CONNECTIONS IN MY SPEAKER
Just a thought ?
PostPosted: Fri May 04, 2007 7:39 am
Most likely a loose connection somewhere.  Check your speaker cables for shorts, the internal speaker wiring for shorts.  Next time it happens, change the speaker channels at the back of the amp, if the problem changes speakers, it's in the wire or speaker, if it stays on the same channel, loose connection is in the amp.
Users browsing this forum: No registered users and 2471 guests
