[ 3 posts ] |
icantgetznosleep
Posted: Thu Mar 29, 2007 11:52 pm |
Joined: Wed Jun 18, 2003 10:00 pm Posts: 23 Been Liked: 0 time
hi guys, looking for dual wireless mic for home use. which one would you choose according to the following specs and why? there is about an $80 difference in cost.
mic 1 specs:
UHF Band Frequency (800MHz)
Two Independent XLR Balanced Outputs
One 1/4" Unbalanced Audio Output
100 Adjustable Frequencies with PLL Synthesized Control
High Sensitivity Cardioid Microphone Capsule
Noise Reduction Mechanism for Eliminating Handling Noise
LCD Display Panel
Frequency Stability 10 ppm
Audio Frequency Response 50 – 15,000 Hz (-3 dB)
S/N Ratio > 105 dB
T.H.D < 1%
Max. SPL 110dB
Range 300 ft
mic 2 specs:
RF Input with Built-in RF Preamplifier to Improve S/N Ratio, Sensitivity and Dynamic Range
Low Noise Mixer Circuitry for Reducing interference
Two Squelch Control Knobs (One for Each Channel) at the Rear Panel
S/N Ratio 80dB
T.H.D. < 1%
Audio Output ¼” and XLR (0 – 300mV @ 600 Ohms)
Low Battery LED Indicator
Audio Frequency Response 80 – 15,000 Hz
S/N Ratio > 80 dB
Max. SPL 110 dB
Range 100 ft
TOMMIE TUNES
Posted: Fri Mar 30, 2007 5:16 am |
| Advanced Poster |
SHURE makes a decent dual wireless set-up that i have sung on at a few venues, it uses a PG-58 mic capsule which is pretty close to a SM-58. is UHF, it has i think 10 selectable channels. it costs about 579.00$ on many pro-audio websites.
twansenne
Posted: Fri Mar 30, 2007 5:30 pm |
Unless you are are very particular and have to have the "best" (a.k.a BD mentality), that's a no brainer. For HOME USE, #2!
Why?
Save the $80 and buy some more CDGs
[ 3 posts ] |
Users browsing this forum: No registered users and 1790 guests |
