KARAOKE SCENE MAGAZINE ONLINE! - Monitors Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 7:26 am
 Post subject: Monitors
PostPosted: Thu Mar 15, 2007 8:18 am
I have a 12" Yamaha Passive Speaker that I would like to use as a monitor.
What type of POWER do you need to put to a singers monitor???
I was thinking of buying a small 80w power amp to hook into my system ?
This way it would cost me about $90 versus $250 for a powered monitor?
What are you using?
 Post subject: Re: Monitors
PostPosted: Thu Mar 15, 2007 10:32 am
I run 2 8 ohm Peavey 12" wedges (1 in each front corner of the stage) ran off a bridged CS200 power amp for 220 watts.  They also have their own 31 band eq for feedback control & to tune them up on stage.
You don't need a whole lot of power for the stage, but would recommend the eq.
PostPosted: Thu Mar 15, 2007 11:10 am
Jam, do you know the model of your 12" yamaha? I run a 12" Yamaha BR12 as my monitor (which is their most popular line of speaker, so odds are it is what you have), and it is rated at 300 watts program (2002 model). I run it through a Samson Servo 300, which bridges mono at 300 watts. I got this amp on sale for around $160.00, so that isn't too bad to properly drive the speaker.
PostPosted: Thu Mar 15, 2007 11:56 am
I'll check the model number tonight and list in the am
PostPosted: Fri Mar 16, 2007 10:12 am
I use 4 YAMAHA CLUB SERIES 12inch For Monitor Mixes, 2 on Stands, Next To My Mains, And 2 On The Floor Driven By A CROWN-XLS-602 Which Is 370 Watts Per Channel Into 8 Ohms, The Vocals Cut Through The Mix Real Nice, In Addition To Another Monitor Mix From 2 MACKIE-SRM-450s On The Floor Also. :read:
PostPosted: Fri Mar 16, 2007 11:20 am
Been Liked: 15 times
Watts do not translate directly into volume.  Certainly 400 watts prduce more music power than 200 but not twice as much.  I would think that 80 watts for a monitor amp is plenty.  the singer just needs to be alble to hear the mix clearly.
Okay, who took my pants?
Users browsing this forum: No registered users and 1948 guests
