Balanced - Unbalanced mics?
https://ksmo.us/forums/viewtopic.php?f=1&t=9416
Author:  easyeasy [ Sat Feb 10, 2007 8:47 am ]
Post subject:  Balanced - Unbalanced mics?
Hi Guys,
I've bought a CAVS 105G player which came with a M-10 mic and cable.
One end of the cable has a XLR connector the other end a 1/4 inch plug (unbalanced - only 1 black ring around it).
I've also bought a SONY F-V 420 mic with the same cable as the CAVS mic.
The question is can I change these cables with XLR-XLR cables (balanced).
Or is there such a thing as balanced and unbalanced mics?
Thanks everyone in advanced for your help and input.
Happy Karaokeing.
Author:  gator [ Sat Feb 10, 2007 8:54 am ]
Post subject:  Re: Balanced - Unbalanced mics?
I don`t see why you couldn`t use XLR TO XLR cbles on your mic.
Author:  twansenne [ Sat Feb 10, 2007 12:33 pm ]
If you are hooking the mics directly into the CAVS unit, no need to change cables since the CAVS unite (I assume) dose't have XLR inputs.
Now if you are suing a seperate mixer, yes you can use XLR to XLR cables.
Author:  Lonman [ Sat Feb 10, 2007 8:19 pm ]
twansenne @ Sat Feb 10, 2007 12:33 pm wrote:
Now if you are using a seperate mixer, yes you can use XLR to XLR cables.
With a separate mixer, this would be the preferred connection also.
