KARAOKE SCENE MAGAZINE ONLINE! - Balanced - Unbalanced mics? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 6:02 am
PostPosted: Sat Feb 10, 2007 8:47 am
Hi Guys,
I've bought a CAVS 105G player which came with a M-10 mic and cable.
One end of the cable has a XLR connector the other end a 1/4 inch plug (unbalanced - only 1 black ring around it).
I've also bought a SONY F-V 420 mic with the same cable as the CAVS mic.
The question is can I change these cables with XLR-XLR cables (balanced).
Or is there such a thing as balanced and unbalanced mics?
Thanks everyone in advanced for your help and input.
Happy Karaokeing.
PostPosted: Sat Feb 10, 2007 8:54 am
I don`t see why you couldn`t use XLR TO XLR cbles on your mic.
Gator
PostPosted: Sat Feb 10, 2007 12:33 pm
Been Liked: 53 times
If you are hooking the mics directly into the CAVS unit, no need to change cables since the CAVS unite (I assume) dose't have XLR inputs.
Now if you are suing a seperate mixer, yes you can use XLR to XLR cables.
PostPosted: Sat Feb 10, 2007 8:19 pm
twansenne @ Sat Feb 10, 2007 12:33 pm wrote:
Now if you are using a seperate mixer, yes you can use XLR to XLR cables.
With a separate mixer, this would be the preferred connection also.
Users browsing this forum: No registered users and 2005 guests
