LHP
Posted: Thu Feb 01, 2007 8:35 am |
Joined: Fri Dec 29, 2006 10:02 am Posts: 37 Been Liked: 0 time
Ok, the folks at Power Burner have decided that for whatever reason their software will not burn on my computer driver. (HP a1020n with the LightScribe DVD/CD Writer)
It rips ok, and Karaoke Sound Tools did a wonderful job of altering the key changes. However, it will not burn.
They have recommended that I purchase another burner and I need some direction. Obviously I don't want to spend a fortune...since this is strickly for personal use. Office Depot has a Sony CD Writer for $44.00.
Any other ideas....THANKS!!!
twansenne
Posted: Thu Feb 01, 2007 10:49 am |
LHP
Posted: Thu Feb 01, 2007 2:07 pm |
twansenne @ Thu Feb 01, 2007 12:49 pm wrote: Plextor?
That was the first one Power Karaoke recommended as well. However, after reading sone of the posts on here about them...I am hesistant because I am just not that computer savvy.
They also recommended (internal) Pioneer or BenQ.
I may go by the Office Depot and ask them if they will let me try that Sony just to see if it works. And if it doesn't, then I could return it.
Thanks for the direction...you folks are the greatest!!
MorganLeFey
Posted: Thu Feb 01, 2007 2:35 pm |
| Extreme Plus Poster |
plexitor is the one most recommended but even then you have to check the models. there is a website where you can check compatibility for burning cdg but I dunno what it is...perhaps someone else knows
CACTUSJACK
Posted: Thu Feb 01, 2007 2:45 pm |
Joined: Tue Dec 17, 2002 7:58 pm Posts: 115 Location: oklahoma Been Liked: 0 time
amen on the plextor just bought a px-760a...for 69.00 {$99.00- $30.00 mail in rebate} cd/dvd writer 18x....... cal
_________________ cal's quote:"the best things in life are free, yet those things are priceless"
MorganLeFey
Posted: Thu Feb 01, 2007 2:54 pm |
http://www.karaoke-software.net/cdg-burners.html
I simply typed cdg compatible burners to google and that is one of a number of sites that appeared, hope that is of help
twansenne
Posted: Thu Feb 01, 2007 3:53 pm |
LHP @ Thu Feb 01, 2007 10:35 am wrote: They have recommended that I purchase another burner and I need some direction. Obviously I don't want to spend a fortune...since this is strickly for personal use. Office Depot has a Sony CD Writer for $44.00.
If you get the SONY make sure it is CD+G compatiable first, both READ and WRITE. Some drives can only read the CD+G subcode
If I was buying a Plextor (for CD+G use)on budget I would get the 755SA or the 760A
http://www.plextor.com/English/products ... index.html
(NOTE: The 750A can only READ CD+G, not write CD+G)
IMHO Plextor is the BEST!!!!!
jerry12x
Posted: Thu Feb 01, 2007 3:59 pm |
Quote: ="If you get the SONY make sure it is CD+G compatiable first, both READ and WRITE. Some drives can only read the CD+G subcode
Thanks mate,
That was good info for me. :D
LHP
Posted: Thu Feb 01, 2007 4:43 pm |
Thanks for the input folks.
I am going to do some research before I leap.
With the price of that Sony being so cheap...I bet it only reads.
I have also seen some burners that were advertised with dual layering???
I had no clue what that meant.
(I knew I should have just sent the discs to twansenne!)  :worship:
powerkaraoke
Posted: Fri Feb 02, 2007 1:52 am |
Joined: Tue Jun 15, 2004 1:41 pm Posts: 219 Been Liked: 8 times
CD+G compatibility is not important as it was before. Of the new drives only Plextors (and not all of them) provide full CD+G compatibility. Power CD+G Burner software allows to burn with most of the drives that support DAO96 burning mode. While it is hard to tell if Sony drive you are referring to supports DAO96 properly there is a good chance it does. Drives that are known to cause problems are Matshita, HP, and LG.
LHP
Posted: Fri Feb 02, 2007 5:11 am |
powerkaraoke @ Fri Feb 02, 2007 3:52 am wrote: CD+G compatibility is not important as it was before. Of the new drives only Plextors (and not all of them) provide full CD+G compatibility. Power CD+G Burner software allows to burn with most of the drives that support DAO96 burning mode. While it is hard to tell if Sony drive you are referring to supports DAO96 properly there is a good chance it does. Drives that are known to cause problems are Matshita, HP, and LG.
Thanks!! I have a bid in on Ebay for a Power Burner (that comes with the Power Burner software I already have.) for $28.00 (including S/H) If I don't win that bid, I will take that DAO96 info with me when I go investigate the Sony.
Wish I was smarter at all this. At my age, I am doing good to push the ON button!
Bebop57
Posted: Fri Feb 02, 2007 5:35 am |
| newbie |
Joined: Mon Nov 13, 2006 10:40 am Posts: 7 Been Liked: 0 time
I have a Sony DRU720 and a Plextor 740U. Both burn Power Karaoke, but the plextor burns at 1X where as the Sony's slowest speed is at 8X. Needless to say I always use the Plextor
dbk1009
Posted: Fri Feb 02, 2007 7:25 am |
Joined: Mon Jul 07, 2003 6:57 am Posts: 477 Location: South Florida Been Liked: 0 time
I just got the Maxell CD burner and it is working to burn, I haven't tried to play off of it yet.
Is that Sony internal or external?
I unfortunately have a Toshiba laptop with a Matshida burner and it DOES not work with ANY meathod....
The Maxell has been good so far.......
_________________ Let's Kick the Tires and Light the Fires!
EElvis
Posted: Fri Feb 02, 2007 8:06 am |
Quote: I have a Sony DRU720 and a Plextor 740U. Both burn Power Karaoke, but the plextor burns at 1X where as the Sony's slowest speed is at 8X. Needless to say I always use the Plextor
I also have the plex 740 (usb). it is the only Burner I have ever found that will read and write Mediaclog disks.
powerkaraoke
Posted: Fri Feb 02, 2007 10:28 am |
With USB enclosure any internal drive can be used as external. And usually it is cheaper than using dedicated external drive.
Jian
Posted: Fri Feb 02, 2007 3:56 pm |
powerkaraoke @ 3rd February 2007, 2:28 am wrote: With USB enclosure any internal drive can be used as external. And usually it is cheaper than using dedicated external drive.
All my 3 'external' drives are in fact internal drives with usb connection. They cost about half the price of the real external.
LHP
Posted: Sat Feb 03, 2007 4:28 pm |
YEA!!!!!!
I had someone recommend a Lite On (External) that I just picked up at Office Depot.
I got the OK from the manager to be able to return it if it did not work...which made me feel better. (I had a $10 coupon, too.)
I just got home and burned my first karaoke master. I have played (and sung) all the songs and they all did beautifully on my VOCO PRO BRAVO.
I am sooo excited. I just wanted to extend a HUGE THANK YOU (especially to twansenne who has been here from the first post) to all of you for giving me the courage to go forward on this. This is something I REALLY REALLY wanted and I would have been to afraid to do it by myself. As a 50+ old lady that is very computer challenged....I could not have done this alone.
Thanks so much...you folks are the BEST !!!!!
ericlater
Posted: Mon Feb 05, 2007 6:04 am |
How much does the Lite On cost?
knightshow
Posted: Mon Feb 05, 2007 6:24 am |
Users browsing this forum: No registered users and 2437 guests |
