| Morgan has a quickie https://ksmo.us/forums/viewtopic.php?f=1&t=9329 |
| Author: | MorganLeFey [ Mon Jan 29, 2007 7:59 pm ] |
| Post subject: | Morgan has a quickie |
just a quick question...anyone know how to rip audio from a dvd? I have am REM dvd and want to extract a song from it as a wave file to see if I can devocalise it. |
| Author: | jerry12x [ Tue Jan 30, 2007 2:02 am ] |
| Post subject: | Re: Morgan has a quickie |
Dunno what software you have. Set windows media recorder, or other, to record. Play your dvd track. Good luck. I have heard some done really well. Others make no differance. Depends on the producer... |
| Author: | MorganLeFey [ Tue Jan 30, 2007 3:24 am ] |
I was kinda hoping for a slightly more tech answer...I want to preserve any layering that may be present |
| Author: | jerry12x [ Tue Jan 30, 2007 3:35 am ] |
Sorry Morgan, Could you please explain what you want to do a bit further. Also what you mean by layering. Only ever heard of that with multi tracking. |
| Author: | jerry12x [ Tue Jan 30, 2007 4:00 am ] |
Just tried LOOSING MY RELIGION in Cool Edit Pro. Worked quite wll. Background ghost naturally. With a bit of EQ it sounds alright. |
| Author: | MorganLeFey [ Tue Jan 30, 2007 4:59 am ] |
jerry12x @ Tue Jan 30, 2007 11:35 pm wrote: Sorry Morgan,
Could you please explain what you want to do a bit further. Also what you mean by layering. Only ever heard of that with multi tracking. I have been told there is a possability that there may be multitracking on the dvd..well in fact there probably is as you can turn the words on and off. its possible that the sound track is also multilayered...who knows unless I try, I just need someone to recommend a prog that will rip the audio, I dont want to copy my whole dvd |
| Author: | jerry12x [ Tue Jan 30, 2007 5:17 am ] |
Sorry, cant help you. The only DVD I have seen was a Legends disk. As far as I recall it didnt layer. Simply had multiple files for each track. |
| Author: | MorganLeFey [ Tue Jan 30, 2007 5:23 am ] |
jerry12x @ Wed Jan 31, 2007 1:17 am wrote: Sorry, cant help you.
The only DVD I have seen was a Legends disk. As far as I recall it didnt layer. Simply had multiple files for each track. this isnt a karaoke disc its a music dvd I want to attempt to strip the vocals from the song |
| Author: | jerry12x [ Tue Jan 30, 2007 5:32 am ] |
Sorry, never heard of that sort of layering. Feel really inadaquate now. |
| Author: | MorganLeFey [ Tue Jan 30, 2007 5:49 am ] |
no need |
| Author: | MorganLeFey [ Tue Jan 30, 2007 6:41 am ] |
ImToo makes a dvd audio ripper. just downloaded it, will only rip 1min 50 without purchase and cant make up my mind if its worthy of paying for it or whether the devoc on a wave file is going to sound significantly better than the one I did on the 128kbs file. To be honest I cant tell the difference there is still a lot of reverb left on the track. I would have to ask an expert |
| Author: | m1532 [ Sat Feb 03, 2007 4:03 pm ] |
You could buy a USB audio capture device for around $50 then you just hook up an RCA cable from your DVD audio out to the devices imputs. Play your DVD and record each song you want as a .wav file then you can burn it to a cd and play in most cd players. |
| Author: | MorganLeFey [ Sat Feb 03, 2007 5:21 pm ] |
yep I could but as stated before would I not potentially be destroying any layering within the original? |
| Author: | Odie [ Sat Feb 03, 2007 5:30 pm ] |
Vicki, I have a DVD to MP3 ripper program that I found earlier. I think it's freeware too. I'll send it to your e-mail address, you can give it a try. |
| Author: | MorganLeFey [ Sat Feb 03, 2007 5:33 pm ] |
thanks don would appreciate that greatly |
| Author: | jerry12x [ Sat Feb 03, 2007 5:57 pm ] |
m1532 @ Sun Feb 04, 2007 12:03 am wrote: You could buy a USB audio capture device for around $50 then you just hook up an RCA cable from your DVD audio out to the devices imputs. Play your DVD and record each song you want as a .wav file then you can burn it to a cd and play in most cd players.
Not sure what your getting at. If you play the dvd in the drive, any recorder s/w would pick it up anyway. Morgan, think I read you had Cool Edit. That is as good a recorder as any... |
| Author: | jerry12x [ Sun Feb 04, 2007 8:01 am ] |
Oh and rips off anything including video. |
