Amps - Low-Cut Filters
https://ksmo.us/forums/viewtopic.php?f=1&t=8980
Author:  homeplateBG [ Wed Dec 27, 2006 6:45 am ]
Post subject:  Amps - Low-Cut Filters
I have two Low Frequency jumpers on the back of my amp.
Low Cut Filter on/off
Low Cut 50Hz/30Hz
I find I get the best sound with LCF off and LC30Hz.  Am I endangering my speakers?  My amp is an EP2500 (behringer).  The manual says the LC50Hz is supposed to give a fuller sound but I find it sounds empty and LCF on is supposed to protect against frequencies under 5Hz.  My speakers are Cerwin Vega PSX-153 3 ways.  I also use Behringer B1520 Pros as a backup set of mains.
Author:  Lonman [ Wed Dec 27, 2006 9:15 am ]
Post subject:  Re: Amps - Low-Cut Filters
Actually if you have the low cut filter switched off, the 30/50 switch shouldn't be doing anything.
Author:  homeplateBG [ Wed Dec 27, 2006 9:17 am ]
That's probably the case.  What's optimal?  Do I risk the speakers by having the low-cut filter turned off?
Author:  Lonman [ Wed Dec 27, 2006 9:24 am ]
Unless you are having problem with low frequency rumble, first switch the mics low frequency switch on on the mic channels.  If the mixer don't have that, then yes I would probably run the low cut filter on at minimum30 hz but probably 50 & compensate the music channel eq a bit.
Author:  homeplateBG [ Wed Dec 27, 2006 9:27 am ]
Thanks Lonnie.  For clarification, unless I'm hearing something out of the ordinary (rumble), having the Low Cut off isn't damaging to the speakers ... musically?  I do have the mic channels low cut on.  Of course your answer will be filtered for subjectivity ...  :)
