KARAOKE SCENE MAGAZINE ONLINE! - Amps - Low-Cut Filters Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 3:04 am
 Post subject: Amps - Low-Cut Filters
PostPosted: Wed Dec 27, 2006 6:45 am
I have two Low Frequency jumpers on the back of my amp.
Low Cut Filter on/off
Low Cut 50Hz/30Hz
I find I get the best sound with LCF off and LC30Hz.  Am I endangering my speakers?  My amp is an EP2500 (behringer).  The manual says the LC50Hz is supposed to give a fuller sound but I find it sounds empty and LCF on is supposed to protect against frequencies under 5Hz.  My speakers are Cerwin Vega PSX-153 3 ways.  I also use Behringer B1520 Pros as a backup set of mains.
PostPosted: Wed Dec 27, 2006 9:15 am
Actually if you have the low cut filter switched off, the 30/50 switch shouldn't be doing anything.
PostPosted: Wed Dec 27, 2006 9:17 am
That's probably the case.  What's optimal?  Do I risk the speakers by having the low-cut filter turned off?
PostPosted: Wed Dec 27, 2006 9:24 am
Unless you are having problem with low frequency rumble, first switch the mics low frequency switch on on the mic channels.  If the mixer don't have that, then yes I would probably run the low cut filter on at minimum30 hz but probably 50 & compensate the music channel eq a bit.
PostPosted: Wed Dec 27, 2006 9:27 am
Thanks Lonnie.  For clarification, unless I'm hearing something out of the ordinary (rumble), having the Low Cut off isn't damaging to the speakers ... musically?  I do have the mic channels low cut on.  Of course your answer will be filtered for subjectivity ...  :)
Users browsing this forum: No registered users and 2462 guests
