[ 5 posts ] |
homeplateBG
Posted: Wed Dec 27, 2006 6:45 am |
I have two Low Frequency jumpers on the back of my amp.
Low Cut Filter on/off
Low Cut 50Hz/30Hz
I find I get the best sound with LCF off and LC30Hz. Am I endangering my speakers? My amp is an EP2500 (behringer). The manual says the LC50Hz is supposed to give a fuller sound but I find it sounds empty and LCF on is supposed to protect against frequencies under 5Hz. My speakers are Cerwin Vega PSX-153 3 ways. I also use Behringer B1520 Pros as a backup set of mains.
Posted: Wed Dec 27, 2006 9:15 am |
Actually if you have the low cut filter switched off, the 30/50 switch shouldn't be doing anything.
homeplateBG
Posted: Wed Dec 27, 2006 9:17 am |
That's probably the case. What's optimal? Do I risk the speakers by having the low-cut filter turned off?
Posted: Wed Dec 27, 2006 9:24 am |
Unless you are having problem with low frequency rumble, first switch the mics low frequency switch on on the mic channels. If the mixer don't have that, then yes I would probably run the low cut filter on at minimum30 hz but probably 50 & compensate the music channel eq a bit.
homeplateBG
Posted: Wed Dec 27, 2006 9:27 am |
Thanks Lonnie. For clarification, unless I'm hearing something out of the ordinary (rumble), having the Low Cut off isn't damaging to the speakers ... musically? I do have the mic channels low cut on. Of course your answer will be filtered for subjectivity ... :)
[ 5 posts ] |
Users browsing this forum: No registered users and 2491 guests |
