KARAOKE SCENE MAGAZINE ONLINE! - Which Mackie's Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 3:21 am
 Post subject: Which Mackie's
PostPosted: Sat Dec 23, 2006 3:10 am
SRM450 or SR1521Z?
I'm going to buy one or the other in the next few days and can't make up my mind!
 Post subject: Re: Which Mackie's
PostPosted: Sat Dec 23, 2006 3:18 am
Really depends on your budget - also are you talking the SA or SR series?  I'd opt for the SA1521 over the SR1521 simply because it has a little more power, the SR has basically the same amps as the 450.  The 1521 is a great speaker if you can afford it, otherwise, the 450's will do a good job too.  Still may want to consider at least 1 sub with either down the line.
PostPosted: Sat Dec 23, 2006 3:35 am
Thanks Lonman. I've already got a 600W powered sub. I just can't decide between the small size of the 450's or the wood of the 1521's.
Can't afford SA's, otherwise I'd be having the SA1530's :yum:
PostPosted: Sun Dec 24, 2006 12:36 pm
Then I would go the SRM450's that should be a great setup :yes:
FlipSide Karaoke
Scott
Users browsing this forum: No registered users and 2176 guests
