ok heres one
https://ksmo.us/forums/viewtopic.php?f=1&t=8944
Author:  dennis [ Fri Dec 22, 2006 2:59 pm ]
Post subject:  ok heres one
roxbox has a feature that lets you record your singers, now my question.
If rox box just manipulates the winamp program can you use win amp to record or do you have to use rox box
see how newbie i bee this must be a dumb question
dd
Author:  exweedfarmer [ Sat Dec 23, 2006 2:18 pm ]
Post subject:  Re: ok heres one
I don't believe Winamp records.  I know another winamp front end, Sacks-O-Nuts had a recording feature that did not use Winamp for that.  In fact the only thing it did use Winamp for was to actually play the Karaoke file and the Key Changer.  I suspect Roxbox might do the same thing.
Author:  karyoker [ Sat Dec 23, 2006 3:57 pm ]
When cueing song check the record box It records into a wav file in folder record...
In the ini file you can change the record path... There is an option to record all but windows has a problem after recording several..
It uses an entirely different recorder and works good other than the bug above....
