KARAOKE SCENE MAGAZINE ONLINE! - Need help to set up a Karaoke system Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 12:37 am
PostPosted: Mon Nov 27, 2006 1:21 pm
Here is a list of equipments I have:
1. Cavs 203 DVD player;
2. Vocopro DA X10 Mixer;
3. Samson stereo compressor;
4. BBE 482i Maximizer;
5. QSC 1080 Amp;
6. Pair JBL EON 15";
7. Vocopro UHF-388 mics.
At first, I only bought a DVD player, a Mixer; an amp; pair of speaker and mics. Then, later I bought a Maximizer and a compressor. After spent hours read manuals and post in this forum, I'm still not have a slice idea how to integrate the maximizer and the compressor into the system. I also bought 2 of insert cables, without knowing that the Vocopro DA X10 doesn't has insert points like other mixers.
Any help and/or advice is appreciated
PostPosted: Mon Nov 27, 2006 1:39 pm
Maximizer will go between your mixer & amp - mixer into BBE, BBE out into amp.  Compressor I answered in the other thread.  Not knowing the model compressor- Samson makes more than 1, it would need to have XLR ins/outs to work.  Hook the mix into the compressor & the compressor outs into the mixer.  Now doing this way won't work as well as if you had a good mixer with inserts.
Which model amp?  I haven't heard of a 1080 model from QSC?
PostPosted: Mon Nov 27, 2006 4:27 pm
Thanks Lon...You'r always have answer...Great...
The Samson compressor is a S.com Stereo Compressor, 2 channels compressor. Yes, it has XLR ins/outs. However, As I said in the last post, The Vocopro DA X-10 mixer has no insert inputs.
Here is the link http://www.vocopro.com/frm_product.html
Thanks..
PostPosted: Mon Nov 27, 2006 4:34 pm
Sorry for my error...it's 1850HD.
PostPosted: Mon Nov 27, 2006 5:33 pm
Alright, i'm assuming you mean the JBL EON 1500 (non-powered) the EON 15 is the powered version.
Nice amp, SLIGHTLY underpowered for those speakers, they want about 450 watts per speaker into 8 ohms, the amp only pushes 360 watts per channel into 8 ohms.  Not a great difference & you probably won't have any problem.
The Samson compressor you must mean the C-Com.  Again, with the XLR, it will work, just not as good as it should with a mixer with inserts.  Run the mic into the input on the compressor & the output of the compressor to the mixer channel input.
PostPosted: Mon Nov 27, 2006 7:36 pm
Lonman @ Mon Nov 27, 2006 5:33 pm wrote:
[  Again, with the XLR, it will work, just not as good as it should with a mixer with inserts.  Run the mic into the input on the compressor & the output of the compressor to the mixer channel input.
Great...Again thanks ...
Connect outputs of the mic's receiver (XLR) to the compressor XLR inputs; Then the compressor XLR outs to the mixer's inputs. However, the Vocopro DA X-10 mixer doesn't has XLR inputs or outputs. All its inputs and outputs on the rear are RCA type connectors. The only 2 outputs are for recorder and pre-amp and inputs are for tape, DVD or ... The mic inputs are on the front and they are 1/4" mono jack (T,S). Is there a reason for them to work only with XLR inputs and outputs ?
PostPosted: Mon Nov 27, 2006 7:50 pm
Have you considered a better mixer?
PostPosted: Mon Nov 27, 2006 7:57 pm
Any recommendation for a new mixer ?
I just spent little over $300 for it. Vocopro said it's a best mixer of Vocopro. Well the more I learned the more I like to go with the expert's advice.
Thanks for your help
PostPosted: Tue Nov 28, 2006 10:32 am
I swear by my Yamaha 16/6FX.....I promise you this mixer is twice as good as the VocoPro unit. Alot of peeps on here are partial to Makie mixers. You can't go wrong with either one, but I perfer the Yamaha.
PostPosted: Tue Nov 28, 2006 1:41 pm
I love and use the Yamaha EMX68s. It is a wonderful mixer...been using it for almost 5 years and nothing EVER goes wrong it! I'm using a pair of Yamaha S115IVS's and they are the same age and sound perfect! I've heard Mackie equipment and I'd put Yamaha up against it any day.
Nothing's harder to put up with than the annoyance of a good example. - Mark Twain
Users browsing this forum: KarenB and 2017 guests
