KARAOKE SCENE MAGAZINE ONLINE! - USB Sound Card? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 2:45 am
 Post subject: USB Sound Card?
PostPosted: Sun Nov 26, 2006 9:30 am
[b I want to be able to play music that is on my puter through my sound system and Im assuming that I can accomplish this with some type of sound card? I would want it to be connected VIA,USB. My question is, is this possible and if so what do you folkes reccomend? Thanking you in advance...[/b]
Gator
 Post subject: Re: USB Sound Card?
PostPosted: Sun Nov 26, 2006 1:30 pm
one of my favorite pieces of hardware...
"Soundblaster MP3+ USB Device"
PostPosted: Sun Nov 26, 2006 1:58 pm
Been Liked: 53 times
DITTO, got 3 of em on eaby for about $15 ea.
PostPosted: Sun Nov 26, 2006 5:07 pm
I use it too
PostPosted: Sun Nov 26, 2006 5:13 pm
Do you use this to run your show?
Gator
PostPosted: Sun Nov 26, 2006 6:29 pm
Yes, on both systems.
PostPosted: Mon Nov 27, 2006 1:38 am
I hate to say this but.....
You seriously think that a $15 sound card is the best one you can use?????
PostPosted: Mon Nov 27, 2006 1:54 am
Been Liked: 8 times
to quote the words of one of the gurus that is normally here but is missing in action soundblaster is great for reproduction of sound but not so good for recording. I have a soundblaster live usb external and it sounds fine for playback was always disappointed in the sound of recordings however
PostPosted: Mon Nov 27, 2006 3:53 am
Great now I know what I need now as usual I have the hook up question... I have a Peavey XR600G Mixer Amp.,is it possible for you or anyone else to  walk me thru the hook up process? Thanking you again...
Gator
PostPosted: Mon Nov 27, 2006 3:54 am
Mine was $39.00 :)
PostPosted: Mon Nov 27, 2006 4:06 am
mroctober @ Mon Nov 27, 2006 5:54 am wrote:
Mine was $39.00 :)
Can you tell me the hook up process Im using a Peavey XR600G Mixing Amp.?
Gator
PostPosted: Mon Nov 27, 2006 4:46 am
Been Liked: 8 times
ok its similar to my peavy if you want to set it up for playback you would simply plug into either channel 7 or 8 that have a left and right jack
if you wish to take a line from your mixer to the soundcard to record take it from the left and right outputs on the bottom right of your mixer and into your line in of your soundcard
if you wish to cancel out the speakers and record using headphones simply put a dummy jack in the extreme right jack point on the row on the bottom right of your mixer and then take it out when you want the audio to go back thru speakers
no doubt I havent been as techy as many others but hope that helps
PostPosted: Mon Nov 27, 2006 6:21 am
Mine was $39.00 :)
that's about what I paid...
Morgan, I record off my amp... the only thing this soundcard does is convert the signal to rca connections, which I hook up as the "cd" connection. I record off the pre-amp out.
I've never had one complaint about sound. I'm no techie, so I can't argue the specifics of the Delta card, or whatever vs the Soundblaster MP3+ USB device.
I will say I've tried soundblaster CARDS and found them wanting for pure audio. But this sucker is a hidden gem!
PostPosted: Mon Nov 27, 2006 11:07 am
Been Liked: 8 times
Mine was $39.00 :)
sweety I have re-read what I wrote and I am sure it cant be construed as a criticism of you, your soundcard or for that matter the size of anyones manhood. Blessed be ;-)
PostPosted: Mon Nov 27, 2006 11:13 am
How does this one compared with Creative SoundBlaster USB Live 24-bit External? Always wanted to know...
PostPosted: Mon Nov 27, 2006 1:36 pm
I really like the Audiophile USB external soundcard
PostPosted: Mon Nov 27, 2006 3:40 pm
How bout this one?http://www.circuitcity.com/ssm/Creative-Labs-Sound-Blaster-Live-24-Bit-External-USB-1-1-SB0490/sem/rpsm/oid/109302/catOid/-13040/rpem/ccd/productDetail.do
Gator
PostPosted: Mon Nov 27, 2006 5:07 pm
Been Liked: 8 times
this is the one I have and have replaced with m-audio fastrack recording usb interface. the playback on the sb external is fine. I found the recording quality left something to be desired. It was substandard even to the sb live internal card in my opinion
PostPosted: Mon Nov 27, 2006 7:08 pm
well, talking about deals, how about this:
click here
add something small to make the total over $50, then use google check out to save $20, that make your sound card 30 bucks or so.
PostPosted: Sat Dec 09, 2006 7:18 pm
I've used both a Creative Labs MP3+ and the ADS Tech USB soundcards with excellent results.  I'm looking at the Mackie d.4 that will be out later next year for DJ'ing and I'll be able to play music directly through it over firewire.  Might add the firewire card to my Mackie Onyx 1620 and playback through it though.
There are LOTS of options out there... a little checking will show you LOTS of possibilities from Creative Labs, M-Audio and plenty of others....  I've had good results with many of them...
Users browsing this forum: No registered users and 2080 guests
