[ 11 posts ] |
Blackrose
Posted: Fri Nov 24, 2006 9:48 pm |
Joined: Fri Oct 28, 2005 8:47 pm Posts: 150 Location: Medford Or Been Liked: 0 time
I am curious if it is possible to to show lyrics on one screen, hoster on another, and then on a projector, winamp visualizations (the ones that come with it, that move to the music). If so, what would someone need for this type of setup. I have a video card HIS Radeon 9800 pro with s video, dvi, and monitor out. Thank you.
knightshow
Posted: Sat Nov 25, 2006 5:37 am |
it is.
you need a normal dual video card (or better), and a projector that has rca or svideo type connections, or a connection that is computer based, and you'd have to run an adaptor!
Many IT presentations are made this way.
Blackrose
Posted: Sat Nov 25, 2006 8:33 am |
So I could have the hoster on one screen, the lyrics playing on another and running a visualization on the projector all at the same time!
twansenne
Posted: Sat Nov 25, 2006 8:40 am |
Blackrose @ Sat Nov 25, 2006 10:33 am wrote: So I could have the hoster on one screen, the lyrics playing on another and running a visualization on the projector all at the same time!
Yes, but you will need a computer with the capabilities of 3 SEPERATE video outputs, that are compatiable with the devices you need to send the seprate "feeds" to.
Easiest with a desktop/rackmount computer. Just put 3 video cards in it. Or one DUAL vidoe card, and one additional video card.
eben
Posted: Sat Nov 25, 2006 11:00 am |
As stated, you will need 3 separate video output, which can only be done with two or more video card. However, you will need some serious horse power and memory to do that without any slow down.
My suggestion is to make sure you get at leat 2GB of memory and high power processor and load it with only bare minimum software you need. Once you get it all loaded, check your memory usage and you have some head room, if not, add more memory.
Blackrose
Posted: Sat Nov 25, 2006 5:20 pm |
ok so on the card, I can hook up 2 monitors and run extended desktop. Then run an s video to a tv. This will not get me 3 video feeds?
It is not imperative, but would like to atleast show the words on both the projector and tv and have the hoster screen separate. The visuals really are not needed.
eben
Posted: Sat Nov 25, 2006 8:25 pm |
Blackrose @ Sat Nov 25, 2006 5:20 pm wrote: ok so on the card, I can hook up 2 monitors and run extended desktop. Then run an s video to a tv. This will not get me 3 video feeds?
If you have two connector plus S-Video on a card, it will let you choose 2 out of 3 connections. That's it. Whether you do extended desktop or not, you can only run 2 outputs from those cards. You will need to get a second card for sure if you want 3 things running at once.
Blackrose
Posted: Sun Nov 26, 2006 8:45 am |
Ah I see! Thank you all for your help on this. I will just have to run 2 feeds only. No biggie.
Blackrose
Posted: Mon Dec 04, 2006 10:29 pm |
Ok on my video card I have 2 outputs for 1 or 2 monitors and then an s video output. What I want to do is run a monitor for the hosting program, and then display lyrics on 2 different tvs. So what are my options? Thank you very much!
eben
Posted: Tue Dec 05, 2006 12:08 am |
Blackrose @ Mon Dec 04, 2006 10:29 pm wrote: Ok on my video card I have 2 outputs for 1 or 2 monitors and then an s video output. What I want to do is run a monitor for the hosting program, and then display lyrics on 2 different tvs. So what are my options? Thank you very much!
If that's what you want to do, you can use either the vga connector to the monitor for the hosting program and use the S-Video to a splitter and use the two connectors to two different TVs. They will display the exact same image on both screens. It's pretty simple.
Blackrose
Posted: Tue Dec 05, 2006 7:33 am |
That is kind of what I thought, just wanted to make sure. Thank you very much!
[ 11 posts ] |
Users browsing this forum: No registered users and 1925 guests |
