KARAOKE SCENE MAGAZINE ONLINE! - Cdrwin Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Thu Nov 05, 2026 12:29 am
 Post subject: Cdrwin
PostPosted: Mon Nov 13, 2006 9:41 pm
Is there any way CDRWIN can burn a copy of a disk without saving in a file on the hardhard, then burning it? Like Nero can do?  Also, any way the player itself can be made larger on the screen?
Does a zipped file have to be unzipped first  before it can be burned to a disk and is this possible?
thank you
 Post subject: Re: Cdrwin
PostPosted: Tue Nov 14, 2006 1:38 am
thank you
If you have 2 players the can read/write cdg subcode, then yes it will, you need to click on back up disc on the main menu & copy directly to disc.
Don't know much about zip files.  Probably would need to be unzipped & burned using another program, not sure.
PostPosted: Tue Nov 14, 2006 5:47 am
cdrwin won't read inside a zipped file, so yes, it needs to be unzipped. If it's in a compressed format, such as mp3+g, you need to reconvert that to a .bin format using mp3toolz or another such converter.
CDRWIN only recogonizes .bin, .wav or .iso files. For purposes of the karaoke, it's .bin
PostPosted: Wed Nov 15, 2006 9:39 pm
I'm running CDRWIN Pro, and I don't see anything on the menue about backing up a disk?
PostPosted: Thu Nov 16, 2006 2:22 am
It's the 2nd icon on the main menu when you start the program!
Users browsing this forum: KarenB and 2079 guests
