removing duplicate mp3g files from hard drive
https://ksmo.us/forums/viewtopic.php?f=1&t=8437
Author:  texwire [ Mon Nov 06, 2006 4:04 pm ]
Post subject:  removing duplicate mp3g files from hard drive
Does anyone know of a program that I can o into my hd and remove duplicate mp3g's
Author:  Lonman [ Mon Nov 06, 2006 4:42 pm ]
Post subject:  Re: removing duplicate mp3g files from hard drive
If you are going to remove, it's better to take the time & go through the dups & determine the best version.  A program may not take that into consideration & just delete the first version it sees maybe leaving the worst Nu-Tech version over the hottest Sound Choice version.
Author:  twansenne [ Mon Nov 06, 2006 6:53 pm ]
In addition to lonman's comments, to do it manualy, you may not want to delete all versions of a song, just the crappy ones.
I myself am in the process of removing "BAD" versions of dupes.  I use a script in EXCELL that finds the dupes by filename from a songlits that Sax&Dotty's generates of all my karaoke songs.
Author:  Guest [ Mon Nov 06, 2006 10:17 pm ]
It's no going to really reduce the size of the hard drive needed.   If there was a way to designate the best version, that would be OK.   Or just put the best musical version in the song book. :yes:
You will also need to verify that each song file, actually matches the song title.
Author:  texwire [ Tue Nov 07, 2006 7:19 am ]
Ok thanks. :wave:  I Just thought maybe there was a program to pick out the dupe songs to make it easy to remove them rather than go search my hd... LMAO
Author:  Tony [ Tue Nov 07, 2006 9:48 am ]
There are numerous utilities out there that will search your HDD for duplicates, not just file name, but also bit size, so it will show you identical files, doing a true byte by byte comparison. No software will find good/bad versions, but only exact versions.
http://www.programurl.com/software/dupl ... finder.htm
Author:  MorganLeFey [ Thu Nov 09, 2006 2:53 am ]
:wave:
