KARAOKE SCENE MAGAZINE ONLINE! - removing duplicate mp3g files from hard drive Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 11:57 pm
PostPosted: Mon Nov 06, 2006 4:04 pm
Does anyone know of a program that I can o into my hd and remove duplicate mp3g's
PostPosted: Mon Nov 06, 2006 4:42 pm
If you are going to remove, it's better to take the time & go through the dups & determine the best version.  A program may not take that into consideration & just delete the first version it sees maybe leaving the worst Nu-Tech version over the hottest Sound Choice version.
PostPosted: Mon Nov 06, 2006 6:53 pm
Been Liked: 53 times
In addition to lonman's comments, to do it manualy, you may not want to delete all versions of a song, just the crappy ones.
I myself am in the process of removing "BAD" versions of dupes.  I use a script in EXCELL that finds the dupes by filename from a songlits that Sax&Dotty's generates of all my karaoke songs.
PostPosted: Mon Nov 06, 2006 10:17 pm
It's no going to really reduce the size of the hard drive needed.   If there was a way to designate the best version, that would be OK.   Or just put the best musical version in the song book. :yes:
You will also need to verify that each song file, actually matches the song title.
PostPosted: Tue Nov 07, 2006 7:19 am
Ok thanks. :wave:  I Just thought maybe there was a program to pick out the dupe songs to make it easy to remove them rather than go search my hd... LMAO
PostPosted: Tue Nov 07, 2006 9:48 am
There are numerous utilities out there that will search your HDD for duplicates, not just file name, but also bit size, so it will show you identical files, doing a true byte by byte comparison. No software will find good/bad versions, but only exact versions.
http://www.programurl.com/software/dupl ... finder.htm
PostPosted: Thu Nov 09, 2006 2:53 am
Been Liked: 8 times
:wave:
Users browsing this forum: KarenB and 1994 guests
