Nero burning problem
https://ksmo.us/forums/viewtopic.php?f=1&t=8434
Author:  redbaron [ Mon Nov 06, 2006 8:10 am ]
Post subject:  Nero burning problem
All of a sudden my Nero is only burning the music and not the text files. Reinstalled software and even replaced burner?
Any suggestions
Thank you
Author:  knightshow [ Mon Nov 06, 2006 9:39 am ]
Post subject:  Re: Nero burning problem
what type of burner are you using? Type of O.S.? What version of Nero?
Author:  Tony [ Mon Nov 06, 2006 9:49 am ]
http://www.karaokeplayground.co.uk/help/help.htm
Author:  redbaron [ Mon Nov 06, 2006 11:54 am ]
i/o Magic LightScribe DDL, also was using Memorex DDL and it did it there also.
Windows XP Pro, Nero 6.6.0.19
thanks
Author:  redbaron [ Mon Nov 06, 2006 11:58 am ]
But it worked fine before, same software, used Karaoke type and checked all, raw files, etc. ?
Author:  ericlater [ Mon Nov 06, 2006 7:34 pm ]
Nero Burning ROM and Nero Express will automatically create a log file at the end of every write attempt. (The log file will be created even if the burning process has failed).
The default folder where this log file is saved depends on whether you were using Nero Burning ROM or NeroExpress.
For -> Nero Burning ROM: C:\Program Files\Ahead\Nero
For -> NeroExpress: C:\Program Files\Ahead\NeroExpress
The name of this log file is
NeroHistory.log
Contact Nero support and send them a copy of the log
Author:  ericlater [ Mon Nov 06, 2006 7:36 pm ]
NeroHistory.log
Send a copy of the log to Nero Tech Support
