KARAOKE SCENE MAGAZINE ONLINE! - Pre-amps, amps, mixers Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 11:33 pm
 Post subject: Pre-amps, amps, mixers
PostPosted: Sat Oct 14, 2006 5:59 pm
Hi all, I have been having a horrible time with my recordings and now I know the problem is my inspire pre-amp.  Instead of using this I would like to use a different mixer, amp or pre-amp.  How would I hook a mixer or amp (or do I need both) to my computer?  Any suggestions?
Tammy
PostPosted: Sat Oct 14, 2006 8:06 pm
A bad recording can be due to one or a combination a a few factors. Look at the source, your mic, then your preamp, then your soundcard/audio interface.
What mixer do you use and what soundcard to you have? How do you record? Do you record 'live' thru a karaoke machine or do you separate the vocal track from the backing when you record?
Users browsing this forum: No registered users and 1817 guests
