KARAOKE SCENE MAGAZINE ONLINE! - Mixing in monitors w/ Main (ATTN:KEITH) Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 10:06 pm
PostPosted: Tue Oct 03, 2006 11:15 am
Been Liked: 53 times
[quote="Keith02 @ Mon Oct 02, 2006 11:40 pmIf you happen to be running your mains in stereo off an unbridged amp, you can actually connect a third speaker across the red binding posts and use it as a floor monitor or far field cabinet.
Yep, I swear you can safely do that.......The amp will be operating in stereo like before  with an 8 ohm speaker on each channel and an 8 ohm speaker for a monitor, but the amp power-wise will think it is operating in bridged mode into a 4 ohm load, and the monitor will get a mono signal which is what you want anyway.[/quote]
Ok, sonds like a GREAT IDEA, and I am in, but it still is a bit confusing.
PIC or a diagram?????
PostPosted: Tue Oct 03, 2006 11:27 am
It almost sounds like he is describing what a lot of car amps are capable of.
Running both channels stereo for your mains & then bridging the 2 positives for 1 more speaker such as a sub/with passive low pass filter.
I'm not quite sure if this would work on most PA amps.  He did state a Peavey rep stated that.  Most amps I have work either in bridge mode or stereo mode, not both.
PostPosted: Tue Oct 03, 2006 11:32 am
[quote="Lonman @ Tue Oct 03, 2006 1:27 pm"]It almost sounds like he is describing what a lot of car amps are capable of.
Running both channels stereo for your mains & then bridging the 2 positives for 1 more speaker such as a sub/with passive low pass filter. [quote]
Baicaly that would give you stereo sound on your mids and highs, where it matters, and on the low sub freq, it would be a combonation of the 2 channels, thefore MONO on the sub??????????
PostPosted: Tue Oct 03, 2006 12:00 pm
That's how it works with alot of car amps, yes.  Again, not sure if it could be put into use with most PA amps.  Would like to know more on where Keith got that info myself.
PostPosted: Tue Oct 03, 2006 12:36 pm
SOunds like that is what he is getting at.  If you ran a stero system, and hooke in a monitor, to only the left or right channel, then the monitor would only have the music from that channel.  Thus by "bridging" the 2 stero chennels, it would give you mono in the monitor, and still maintain your stero for the mains.  At least that is what I am thinking.
But I guess, since I run in MONO (2 amps not bridged), since a lot of places I play have funky speaker placements, just putting the monitor on either the left or right channel would not make a difference since the sound is still mono.
PostPosted: Tue Oct 03, 2006 11:09 pm
ARRRRGGGGGHHHHH!...I can't find the link I'm looking for!...I thought i had the right one.....I'll keep looking
PostPosted: Tue Oct 03, 2006 11:20 pm
Ain't no such thing as unbridged mono on a two channel amp.....unbridged is left/right, bridged is mono....
PostPosted: Wed Oct 04, 2006 12:15 am
For the amp to function properly you would have to run the amp in bridged mono mode at that point you would only be sending a positinve singal to the one main speaker and a negative to the other.
The comparison is to a 4 channel amp running one stereo set and the second 2 channels in mono bridged there are Crown amps manufactured that will do this properly.
I wouldn't want to see allof the bad things that would happen by this suggestive setup.
PostPosted: Wed Oct 04, 2006 12:36 am
Still looking :(
PostPosted: Wed Oct 04, 2006 6:47 am
Once again they have taken a simple concept and over complicated it'
Lets say you have a 10 volt power supply Disregarding efficiency and other factors it can handle a 5 volt postive and 5 volt negative swing in voltage... (10 volt peak to peak)  Now if you take one channel and invert the phase 180 degrees so they are working in a push pull fashion you get a 20 volt peak to peak swing..  Then you invert the phase back 180 degrees to keep the speakers in phase.  This is a bridged amp..
What they are doing with the car amps is hooking the left right  on both sides of the speaker for a pushpull arrangement using both channels to drive one speaker The result is mono and each amp sees 4 ohms versus 8... Note the signals are 180 out of phase...
PostPosted: Wed Oct 04, 2006 2:48 pm
OK, I guess I should restate....me runing a MONO sound, into 2 amps that are not bridge.
I don't want my music in stero, becasue of  some funky speaker placements a some place I play.  If it were in stero, and something like Led Zeppelin was playing where the music pans back and forth, it would not be a good effect since the speaker can't be set up to provide that effect.  Therefore my sound is MONO, but I am running 2 amps, one fore each speaker, or set of speakers.
Hope ya understand.
PostPosted: Wed Oct 04, 2006 3:16 pm
Not sure.  I had an old Punch amp.  It was stable down to nearly 1 ohm.  It was able to run a set of stereo mains AND a bridged sub with filter/choke - tapped off the 2 positives of each speaker channel.  The only thing that was mono was the sub, the 2 mains were a well defined left & right all running on the same amp.  Really don't know what it did to the ohms & watts each speaker actually recieved.
PostPosted: Wed Oct 04, 2006 3:44 pm
 I aint sure either but dont know what you mean by bridged sub Lon... Did the filter assembly have a transformer that inverted the polarity? To me hooking both positives to opposite sides of a speaker would cancel out but like the pic above if one was inverted it would work..... You got me curious now...
PostPosted: Wed Oct 04, 2006 3:56 pm
Keith,
Is this what you are looking for for?
I can show you how to get +6 dB more performance out of this system with no more financial investment, while having the system configured to prevent anyone from changing the calibration of the Near and Far Field gain structure. The secret to this application is to operate the CS-800X in bridge mode. Connect the Far Field HDH-244T across the two red binding posts of each channel, i.e., in normal bridge mode operation. Then you would connect one of the Near Field HDH-244T's, across the A channels' red and black binding posts. Next, the second Near Field HDH-244T would be connected across the B channels' red and black binding post; however, (note) the second Near Field HDH-244T, that is connected to the B channel output, would have the loudspeaker leads reversed. This is very important, since the B channel is out of phase with the A channel, you don't want the second Near Field speaker to be out of phase, so reversing the loudspeaker leads will maintain the proper polarity. In this application I would recommend reversing the loudspeaker leads at the speaker itself.
This would prevent someone from noticing the different color wires on the A & B channels' red and black banana posts, thinking they are "correcting" someone else's error by changing them around. In this application with a CS-800X, the Far Field HDH-244T would automatically have +6 dB more gain than the Near Field HDH-244T loudspeakers. When the Far Field loudspeaker receives 800 Watts from the power amplifier, each of the Near Field speakers would receive 200 Watts. I have shown you a way in this application to obtain +6 dB more performance in both the Near and Far Field, with no more investment in dollars. Typically, you would have had to quadruple the number of loudspeakers to obtain +6 dB more system performance.
PostPosted: Wed Oct 04, 2006 5:32 pm
The filter was just a large wire coil wrapped around a hollow iron rod.  6.6mh.  The place that made it was Chokes Unlimited - basically a low pass filter was all it was.  They specialize in speaker crossover components.
This is exactly how the stereo store hooked it up according to the amps diagram hook up.
PostPosted: Wed Oct 04, 2006 6:05 pm
LMAO
I dont know .....Usually a choke in series like in a power supply is used to filter out 60 hertz or hum.... Ok... they were using it for a load to pass low's to the speaker....Im slow....But you still need to invert the polarity on one leg to power the speaker. I would have to see the schematic but the critical part would be polarity thru out...
PostPosted: Wed Oct 04, 2006 6:09 pm
Alls I know is it worked & sounded pretty decent.
Users browsing this forum: No registered users and 2042 guests
