KARAOKE SCENE MAGAZINE ONLINE! - karaoke files on hard drive Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 10:47 pm
PostPosted: Sun Oct 01, 2006 8:05 am
hi
i have down loaded some karaoke files but they have 2 files i mp3 and 1 cdg file how can i intergrate them together to play as one and which software do i need to play them on the pc
PostPosted: Sun Oct 01, 2006 8:53 am
Been Liked: 53 times
Winamp with the CD+G plugin installed is all you need
PostPosted: Sun Oct 01, 2006 11:42 am
thanks
just one more question
if i had a karaoke dvd which soft ware do i use to rip to the hard drive and will win amp still play them???
PostPosted: Wed Oct 18, 2006 12:27 am
Hey I just joined the site but i wanted to answer your ?
I think that you are wanting powerkaraokeburner it will rip in your stuff and it will merge the two files pjense2002@gmail.com if you are interested i will send you a link :drunk:
PostPosted: Fri Oct 20, 2006 6:47 pm
Been Liked: 8 times
first you dont combine the mp3 +cdg they are two seperate tracks. winamp with the correct plug in will recognise you have the cdg and play it as soon as you load the mp3 part of the song. you simply unzip the two parts into the same folder and you wont have to worry again.
secondly audiograbber does a very good job of ripping cdg disc to mp3+cdg it also will give you the option to rip to bin which is what you would need should you be making a copy of your original disc so as you have a back up
Hope this helps
Oh one more thing. If you have winamp and the appropriate cdg plug in you may like to look at sax & dottys which is a play that will play the zipped files without the need to unpack them. This saves on a bit of space :)
PostPosted: Fri Oct 20, 2006 6:56 pm
Hope this helps
Or get autokdj which is freeware that intigrates itself into winamp's Media library and also puts zip control into winamp itself so you don't need an outside program doing all the work.
As for dvd karaoke, you can convert dvd to vcd dat files which are playable in winamp.   for $39 you can get VJRipper from www.clubdjpro.com to convert your dvd's into VCD.
Users browsing this forum: No registered users and 1745 guests
