1/4 in jack versus audio (red & white)
https://ksmo.us/forums/viewtopic.php?f=1&t=8053
Author:  basement karaoker [ Sat Sep 23, 2006 11:54 am ]
Post subject:  1/4 in jack versus audio (red & white)
I was thinking of getting the Delta 44, when i noticed it has 1/4 jacks out. I have a pmx2000(behringer power amp). My channel now that I have the CD & g player going in its channel 10 (no 1/4 in jacks). It has the audio jacks(red & white). It aslo has the phantom power on it. Im not sure what phantom power is for, but only channel 10 has it. If i get the Delta 44, and covert the 1/4 jack to audio jacks, will it kill the sound. I could go 1/4 in jack to 1/4 jack on channel 7-9, but there is no phantom power. I want o buy the better stuff, instead of the soundblaster mp3 + box. I eventually will load all songs in the computer.
Thanks for all the help!!!
Author:  Keith02 [ Sat Sep 23, 2006 12:08 pm ]
Post subject:  Re: 1/4 in jack versus audio (red & white)
your mixer is properly set up to accept the Delta 44. Use the stereo strip with 1/4" jacks.
Phantom power is only to be used whenever you connect a condensor microphone to the mixer. Condensor mics require voltage from the mixer to operate properly. You usually will not harm a regular dynamic mic with phantom power, but it is best not to use it except for condensor mics.
Author:  Guest [ Sat Sep 23, 2006 12:27 pm ]
The red & white as you call them are referred to as, RCA plugs.
