[ 9 posts ] |
twansenne
Posted: Sat Sep 16, 2006 12:28 pm |
I assume you mean DUAL displaly.
Yes you can put visiulations, videos, and other things on the 2nd screen, just drag them over there, or check settings.
Guest
Posted: Sat Sep 16, 2006 12:49 pm |
Is the computer configured for the second display? It just doesn't happen you have to set it up.
knightshow
Posted: Sat Sep 16, 2006 2:22 pm |
actually dog, most pcs WILL boot up and recognize the dual display.
Twan is right... you click and drag it over... unless you have a program that will auto sense it and configure it, such as clubdjpro!
Guest
Posted: Sat Sep 16, 2006 11:21 pm |
I have a 2 year old laptop that has XP on it and has the extended desktop. I have a 1 year old desk top with XP that doesn't have it.
EZduzzit
Posted: Wed Oct 11, 2006 11:52 am |
Joined: Sat Feb 18, 2006 8:41 am Posts: 14 Location: Baltimore, MD Been Liked: 0 time
I'm having the same proplem with my tv display. Were you able to fix the problem?
_________________ I don't ask stupid questions, I'm an inquisitive idiot.
Guest
Posted: Thu Oct 12, 2006 6:59 am |
Can you go in to your display settings and actually see two displays? It will show two monitors in the settings. If it don't, it don't.
EZduzzit
Posted: Thu Oct 12, 2006 7:10 am |
I figured it out, i had to go to my graphic card settings and enable the extended desktop. I tried to do it in my display settings, and it wouldn't work. Now when I turn on the computer I have to right click the ATI icon at the bottom and select "Extended Desktop". Seems to work ok.
JDrifter
Posted: Thu Oct 12, 2006 7:21 am |
Assuming that you have already hooked up the TV to the S-Video out of your PC or laptop, you need to turn on the TV before booting up the PC or laptop. You should see the TV screen flicker and then the boot up screen for Windows. Once Windows has completed its boot sequence, you right click on an empty space on the desktop, click on properties to open up "Display Properties". Click on the "Settings" tab. You should see Monitor 1 and Monitor 2. If not, click on the check box for "Extend my Windows desktop onto this monitor".
Depending upon your hosting software, when you play MP3+G, you should see the lyrics on the TV screen. If not, click on the screen on your PC or laptop and drag it on your right until it appears on the TV. You may have to tweak the size to fill up the TV screen.
HTH.
[ 9 posts ] |
Users browsing this forum: No registered users and 1774 guests |
