| software issue! https://ksmo.us/forums/viewtopic.php?f=1&t=7809 |
| Author: | soulman71 [ Fri Sep 01, 2006 8:11 pm ] |
| Post subject: | software issue! |
I downloaded the software in the "switching to pc" thread . and nothing makes sense ans nothing works right. I am using a sony dru 810a burner. I am trying to try this on my desktop before I buy a laptop so I dont waiste money on different software. Roxbox sounds like it will wor well if I had the right system. can anyone help me. I am very frustrated!!!!!!!!!!!!!!!! Thanks! |
| Author: | knightshow [ Sat Sep 02, 2006 6:50 am ] |
| Post subject: | Re: software issue! |
well, you're not mentioning the software you downloaded... which ONE? Roxbox? |
| Author: | soulman71 [ Sat Sep 02, 2006 9:26 pm ] |
not roxbox yet . I wanna get the right burner before i try the demo dont wanna waiste my money if its not the right software! I read where my burner(sony dru 810a) was cdg compatible but I cant make it work. So i guess i will have to get a plextor. money, money money!!!!!!!!!! plus I havent bought my laptop yet. I'm trying to figure all this out before I buy one. Again I wanna make sure I get the right one! Thanks! |
| Author: | Guest [ Sat Sep 02, 2006 11:50 pm ] |
Burning software for some reason doesn't work with all burners. Try the software site for a list of compatable burners. I know CD Clone works with certain models of HP burners better than other ones. They will list exact models numbers. They meant it. |
| Author: | Keith02 [ Sun Sep 03, 2006 3:50 am ] |
Are you saying the burner will not work at all, or it will not burn cdg's? |
| Author: | soulman71 [ Sun Sep 03, 2006 6:33 am ] |
sony dru 810a works great....just not cdg compatible |
| Author: | knightshow [ Sun Sep 03, 2006 9:15 am ] |
I've been getting plextor burners on Ebay pretty cheap. Check out either the list from MTU for compatible... or http://www.goldenhawk.com for the correct devices Not all plextors will work with the software!! |
| Author: | Keith02 [ Sun Sep 03, 2006 10:14 am ] |
I've also had good luck with most HP burners working well burning cdg's. I suggest you contact Sony tech and see if they offer a solution. There might be a driver issue involved. Did you allow Winduhs to plug n play it or did you install the drivers that came with it? If you had a driver floppy/cd that came with it, remove/unplug the cdrom, go into device manager and remove the drivers windows assigned to it, then install the Sony drivers, then reinstall/reconnect the cdrom and try it again, also look on the Sony support site for latest drivers before you do anything. |
| Author: | soulman71 [ Mon Sep 04, 2006 8:33 pm ] |
thanks alot for your help!
| Author: | covertunes [ Wed Sep 13, 2006 1:11 am ] |
i use powercd+g burner. it will recognize just about ANY drive. |
| Author: | covertunes [ Wed Sep 13, 2006 1:15 am ] |
http://www.powerkaraoke.com/src/prod_powercdgburner.php download powercd+g demo here. you can see if it recognizes your drive before you buy it. |
| Author: | DannyG2006 [ Wed Sep 13, 2006 5:32 pm ] |
I have a lite on 16x dvd rom that works great with KJrip n zip. |
