jdmeister
Posted: Sat Aug 26, 2006 6:40 pm |
Joined: Sun Mar 24, 2002 4:12 pm Posts: 7731 Songs: 1 Location: Hollyweird, Ca. Been Liked: 1096 times
Any good? I hear they actually read CD+G subcode..
I found a source.. Shoiuld I buy a few?
Keith02
Posted: Sat Aug 26, 2006 6:44 pm |
| Super Duper Poster |
jdmeister @ Sat Aug 26, 2006 8:40 pm wrote: Any good? I hear they actually read CD+G subcode..
I found a source.. Shoiuld I buy a few? Man, I dunno...I just bought one and installed it in a PC I sold a friend....I need to go over and install OS for him and get him online...I'll try to remember to try it then.
jdmeister
Posted: Sat Aug 26, 2006 6:48 pm |
The price was ok.. 2 CD readers for $5.00
Keith02
Posted: Sat Aug 26, 2006 6:51 pm |
jdmeister @ Sat Aug 26, 2006 8:48 pm wrote: The price was ok.. 2 CD readers for $5.00  Oh, I thought you meant burners, not ROM's...Yeah, 2.50/each is real good even if they don't do CDG's!
MorganLeFey
Posted: Sat Aug 26, 2006 6:52 pm |
| Extreme Plus Poster |
but doesnt the winamp cdg plugin allow you to read cdg on almost any cdrom now?
Keith02
Posted: Sat Aug 26, 2006 7:09 pm |
MorganLeFey @ Sat Aug 26, 2006 8:52 pm wrote: but doesnt the winamp cdg plugin allow you to read cdg on almost any cdrom now? I dunno, but in my experience so far, the actual player must have the ability too....typically plugins are devised to add extra functionality to a program, not hardware. If the hardware supports that function, then the plugin will allow application to use it.
Some player applications will only work with certain Drives in CDG mode, whereas a few others player applications will work with more Drives, but in the end, the drive must be capable for it to work no matter which program you select.
jdmeister
Posted: Sat Aug 26, 2006 7:25 pm |
I picked up 10.. That should hold me for a while.. LMAO
MorganLeFey
Posted: Sat Aug 26, 2006 7:58 pm |
jdmeister @ Sun Aug 27, 2006 3:25 pm wrote: I picked up 10.. That should hold me for a while.. LMAO
Do you buy wives by the dozen as well?
Jian
Posted: Sat Aug 26, 2006 8:00 pm |
Keith02 @ 27th August 2006, 11:09 am wrote: MorganLeFey @ Sat Aug 26, 2006 8:52 pm wrote: but doesnt the winamp cdg plugin allow you to read cdg on almost any cdrom now? I dunno, but in my experience so far, the actual player must have the ability too....typically plugins are devised to add extra functionality to a program, not hardware. If the hardware supports that function, then the plugin will allow application to use it. Some player applications will only work with certain Drives in CDG mode, whereas a few others player applications will work with more Drives, but in the end, the drive must be capable for it to work no matter which program you select.
Keith, Most CD-ROM CAN read the subcode; I just checked mine and it says it can read. And it is a non brand cdrom.
jdmeister
Posted: Sun Aug 27, 2006 3:46 pm |
Jian @ Sat Aug 26, 2006 8:00 pm wrote: Keith02 @ 27th August 2006, 11:09 am wrote: MorganLeFey @ Sat Aug 26, 2006 8:52 pm wrote: but doesnt the winamp cdg plugin allow you to read cdg on almost any cdrom now? I dunno, but in my experience so far, the actual player must have the ability too....typically plugins are devised to add extra functionality to a program, not hardware. If the hardware supports that function, then the plugin will allow application to use it. Some player applications will only work with certain Drives in CDG mode, whereas a few others player applications will work with more Drives, but in the end, the drive must be capable for it to work no matter which program you select. Keith, Most CD-ROM CAN read the subcode; I just checked mine and it says it can read. And it is a non brand cdrom.
Not most, but quite a few..
Here is a list of drives that will read subcode.
http://www.mtu.com/support/cdr-ide-drives.htm#MicrostudioDrives
Keith02
Posted: Sun Aug 27, 2006 4:35 pm |
MorganLeFey @ Sat Aug 26, 2006 9:58 pm wrote: jdmeister @ Sun Aug 27, 2006 3:25 pm wrote: I picked up 10.. That should hold me for a while.. LMAO Do you buy wives by the dozen as well?  LMAO No need to when they come with a 30 day refund policy.
knightshow
Posted: Sun Aug 27, 2006 9:17 pm |
actually, www.powerkaraoke.com says that they can work with even more than your list from mtu, JD. Not EVERY one out there, but a great deal!
jdmeister
Posted: Mon Aug 28, 2006 9:51 am |
knightshow @ Sun Aug 27, 2006 9:17 pm wrote: actually, www.powerkaraoke.com says that they can work with even more than your list from mtu, JD. Not EVERY one out there, but a great deal!
True, Matt.... but that was the quickest link I had.. LOL
I use Plextor drives normally, but $2.50 a drive was too hard to pass up..
twansenne
Posted: Mon Aug 28, 2006 10:05 am |
I have 2 Lite-On CD drives (read only) that do read the CDG subcode. THey are older, about 5 y.o. I used the CDG disck player plugin in winamp to test/use em
DannyG2006
Posted: Mon Aug 28, 2006 10:32 am |
I have a lite on dvd rom that reads the subcode. right now since my plextor bit the dust it is my importer. as for playing outside cdg discs I would never use the rom inside my computer for that as it will wear the rom out. besides you need a fast computer to do so as it hangs my rackmount with the one used with winamp. if frank would release his I would concsider as the test version uses less resources than what is available now.
jdmeister
Posted: Mon Aug 28, 2006 6:09 pm |
DannyG2006 @ Mon Aug 28, 2006 10:32 am wrote: I have a lite on dvd rom that reads the subcode. right now since my plextor bit the dust it is my importer. as for playing outside cdg discs I would never use the rom inside my computer for that as it will wear the rom out. besides you need a fast computer to do so as it hangs my rackmount with the one used with winamp. if frank would release his I would concsider as the test version uses less resources than what is available now.
My rack is 3.0 gig, and seems fast enough..
Even my laptop, 2.8 seems to work..
twansenne
Posted: Tue Aug 29, 2006 12:49 pm |
DannyG2006 @ Mon Aug 28, 2006 12:32 pm wrote: <<<SNIPPPED>>> I would never use the rom inside my computer for that as it will wear the rom out. besides you need a fast computer to do so as it hangs my rackmount with the one used with winamp. <<<SNIPPED>>>
The rom will wear the rom out??????HUH??????
I have the CDG discplayer plugin for winamp (ver 5) running on a 500Mhz system with 128MB ram, and have NEVER had it hang up from playing a CDG disc.
jdmeister
Posted: Tue Aug 29, 2006 1:38 pm |
Any CD reader/burner has a finite life.. It is after all, just a DC motor and some read write heads..
All things will fail.. Not to mention the "dust factor" on the laser lens...
knightshow
Posted: Tue Aug 29, 2006 1:41 pm |
JD, can ya share the wealth on your source? PM is fine!
DannyG2006
Posted: Tue Aug 29, 2006 2:52 pm |
twansenne @ Tue Aug 29, 2006 3:49 pm wrote: DannyG2006 @ Mon Aug 28, 2006 12:32 pm wrote: <<<SNIPPPED>>> I would never use the rom inside my computer for that as it will wear the rom out. besides you need a fast computer to do so as it hangs my rackmount with the one used with winamp. <<<SNIPPED>>> The rom will wear the rom out??????HUH?????? I have the CDG discplayer plugin for winamp (ver 5) running on a 500Mhz system with 128MB ram, and have NEVER had it hang up from playing a CDG disc.
I'd rather wear out a dvd player that plays cdg's than have to take out a cd-rom that wore out from use. But then again I have yet to need the dvd player so all in all I wasted $24.95 for the cdg disc plugin as it hangs evrytime I went to add music from the hard drive to the que when I tested it. Did not have the issue with frank's alpha version, go figure. I guess I'll wait for kjamp before I 86 my dvd player.
Users browsing this forum: No registered users and 1540 guests |
