mroctober
Posted: Fri Aug 11, 2006 10:58 am |
Joined: Fri Oct 14, 2005 1:52 pm Posts: 680 Location: Gainesville Florida Been Liked: 2 times
Just placed an Order for a mackie CFX12 It should be at my Door Monday Morning.
Cant wait to hear it with my Bose L1 system.
Thanks for all the pro's and Cons on Mixer Choice.
I'll Let ya's Know how it works.
mroctober
Posted: Fri Aug 11, 2006 12:32 pm |
I think you use one of these Mackie's...... do you suggest I run My CD+G thru the 9/10 11/12 Channels instead of the Tape In ?
Posted: Fri Aug 11, 2006 12:35 pm |
mroctober @ Fri Aug 11, 2006 12:32 pm wrote: Lonman I think you use one of these Mackie's...... do you suggest I run My CD+G thru the 9/10 11/12 Channels instead of the Tape In ?
Oh, but of course!
I don't care what mixer anyone runs, the tape in's should not be used. Even if you have to use 2 separate channels to get both inputs, do it. The channel strips are better for everything as you can send the signal to the monitor, add effects if needed, & most importantly - EQ capability. Not all songs are recorded equally & some do require eq adjustments.
mroctober
Posted: Fri Aug 11, 2006 12:40 pm |
Grassy a$$ (thats Spanish)
Thats what I thought.
JDrifter
Posted: Fri Aug 11, 2006 3:29 pm |
Quote: I don't care what mixer anyone runs, the tape in's should not be used. Even if you have to use 2 separate channels to get both inputs, do it.
Hi Lonnie. Does this still hold true if I have a DJ mixer and I want to hook it up to my CFX12 mixer?
BTW, congrats MrOctober! CFX12 is worth the money.
pittsburghpat
Posted: Fri Aug 11, 2006 5:08 pm |
Joined: Thu Jul 27, 2006 11:28 am Posts: 45 Been Liked: 0 time
mroctober @ Fri Aug 11, 2006 1:58 pm wrote: Just placed an Order for a mackie CFX12 It should be at my Door Monday Morning. Cant wait to hear it with my Bose L1 system. Thanks for all the pro's and Cons on Mixer Choice. I'll Let ya's Know how it works.
I had a chance to try out someone's CFX12 recently and I thought it was a real nice board. It worked real well for karaoke. bye pghpat
Posted: Fri Aug 11, 2006 5:31 pm |
JDrifter @ Fri Aug 11, 2006 3:29 pm wrote: Quote: I don't care what mixer anyone runs, the tape in's should not be used. Even if you have to use 2 separate channels to get both inputs, do it. Hi Lonnie. Does this still hold true if I have a DJ mixer and I want to hook it up to my CFX12 mixer? BTW, congrats MrOctober! CFX12 is worth the money.
First question, do you really NEED both mixers hooked up at the same time? I knew one host here that ran a main mixer for karaoke - for the mics, then ran the players through a dj board that would run into the main mixer. I asked why he didn't just use the main mixer for all of it, he told me he didn't know he could run a player through the main board - now he does.
A dj board is a little different than just a player. I have hooked a dj board to the channel strips - keeping the dj board eq flat all the way through, ran it a little less than unity & adjusted the gain on the main board accordingly. But if it works for you to hook it through the tape in, then that's ok too. It has eq'ing & effects, etc... and a player hooked into a dj board first is still getting the eq'ing done on the dj board, a player plugged straight into the tape input does not.
JDrifter
Posted: Fri Aug 11, 2006 5:51 pm |
Quote: First question, do you really NEED both mixers hooked up at the same time?
Good question. I use the DJ mixer to cue music from either player A or player B, with beat matching. If there is a way to do that using only the CFX12, then I would rather use the CFX12 only.
Posted: Fri Aug 11, 2006 6:34 pm |
JDrifter @ Fri Aug 11, 2006 5:51 pm wrote: Quote: First question, do you really NEED both mixers hooked up at the same time? Good question. I use the DJ mixer to cue music from either player A or player B, with beat matching. If there is a way to do that using only the CFX12, then I would rather use the CFX12 only.
No not with the CFX alone. So I take you dj while karaoke as well? No real need to beat match for karaoke alone. I can see cue'ing the idle player, but you don't even need a mixer for that - unless you are bringing it to the beginning of the music - which isn't even necessary in karaoke as some songs actually have lyrics that start before the music.
JDrifter
Posted: Fri Aug 11, 2006 11:09 pm |
Quote: So I take you dj while karaoke as well?
I only do weddings and private parties, so I combine DJ music and karaoke. This is why I find it necessary to use a DJ mixer in addition to the CFX12 mixer.
TOMMIE TUNES
Posted: Sun Aug 13, 2006 3:26 am |
| Advanced Poster |
Their is a Used MACKIE-CFX-12-MK-2 For Sale At WWW.MUSICGOROUND for $379.00 It looks Pretty Decent From The Photo.
MorganLeFey
Posted: Sun Aug 13, 2006 7:14 am |
| Extreme Plus Poster |
TOMMIE TUNES @ Sun Aug 13, 2006 11:26 pm wrote: Their is a Used MACKIE-CFX-12-MK-2 For Sale At WWW.MUSICGOROUND for $379.00 It looks Pretty Decent From The Photo.
Tommy are you sure you arent my husband? or have you just borrowed his trousers with long pockets?
TOMMIE TUNES
Posted: Sun Aug 13, 2006 7:33 am |
| Advanced Poster |
Maybe... Does He Have Short Arms Too?
MorganLeFey
Posted: Sun Aug 13, 2006 7:34 am |
It is you!!!!!!!!!
TOMMIE TUNES
Posted: Sun Aug 13, 2006 7:41 am |
| Advanced Poster |
I've Got MACKIE Taste... On A BEHRINGER Budget.
MorganLeFey
Posted: Sun Aug 13, 2006 7:44 am |
sweety that is better than having behringer taste on a mackie budget
TOMMIE TUNES
Posted: Sun Aug 13, 2006 8:40 am |
| Advanced Poster |
I Couldn't Agree More.. Let's Renew Our Vows! :hug:
MorganLeFey
Posted: Sun Aug 13, 2006 8:48 am |
on your knees and say after me...I promise to love Morgan and all her familiars, her broom is for riding not for sweeping, if the casserole looks and smells a little unusual I vow not to question it and above all I shall make sparing use of love potion no 9 at Beltane
MorganLeFey
Posted: Sun Aug 13, 2006 8:49 am |
And get your nose out of my profile!!!!!!!!
TOMMIE TUNES
Posted: Sun Aug 13, 2006 10:46 am |
| Advanced Poster |
From Mixers To Melodrama , On Second Thought...  [/quote]
Users browsing this forum: No registered users and 1727 guests |
