KARAOKE SCENE MAGAZINE ONLINE! - Just a little levity Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 4:59 pm
 Post subject: Just a little levity
PostPosted: Fri Jul 28, 2006 10:32 am
This is from a friend and I have been holding out for some time. It makes for a long post but I'm sure many of you will enjoy this.
"After every flight, Qantas pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas' pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. (By the way, Qantas is the only major airline that has never, ever, had an accident)
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Could not reproduce problem on ground
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: IFF inoperative in OFF mode.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget." :D
 Post subject: Re: Just a little levity
PostPosted: Fri Jul 28, 2006 10:39 am
LMAO Huge thumbs up!
Very Very funny.  :hi5:
PostPosted: Fri Jul 28, 2006 11:07 am
Years ago I worked on a radar that weighed 25 tons The hydraulics to drive it was massive and sometimes we had to replace couplers etc... I started to unpack a box and there was a warning in big red letters Important Critical Mod Inside.
So I unpacked it and was this little folded paper inside....
click for note
PostPosted: Fri Jul 28, 2006 12:15 pm
Chuck,  that was a good one!
Larry
"Life is too short for diet soda and lite beer"
PostPosted: Fri Jul 28, 2006 2:33 pm
Here are some more that absoutely slay me
PostPosted: Fri Jul 28, 2006 4:58 pm
Been Liked: 23 times
My hubby is an avionics tech.... and, first off, not only is a pilot NOT that stupid, to actually MAKE those complaints... (also... "auto-land"? Wtf is that?) but, those comments would never have been made and allowed to be recorded... imo.
And, I have seen those complaints EVERY where online, all under dif. aircraft companies.... so are they real? Probably not.
But, they ARE amusing:)
PostPosted: Fri Jul 28, 2006 8:24 pm
LMAO
Just a little laughter...
Users browsing this forum: No registered users and 1859 guests
