Ok what the #$^% am I doing wrong?????
https://ksmo.us/forums/viewtopic.php?f=1&t=7378
Page 1 of 2
Author:  MorganLeFey [ Wed Jul 19, 2006 3:18 am ]
Post subject:  Ok what the #$^% am I doing wrong?????
1. my url link on my profile isnt working am I missing something?
2. I can receive pms but when I attempt to respond I push the submit button but they just sit in my outbox and I see no way of sending them
****hovers in front of mirror to check if blonde roots are visible****
Author:  Jian [ Wed Jul 19, 2006 5:43 am ]
Post subject:  Re: Ok what the #$^% am I doing wrong?????
I got all your test pm. its working.
For your url, redo it from your user control panel, it should work, I just try puting my photobucket site up and the link works.
Author:  Lonman [ Wed Jul 19, 2006 7:47 am ]
All PM's will sit in the outbox until the recipient reads it.  Then it will be moved into your sent box.
Your URL link has the karaoke-forum.com (this site) in front of it.  You may have copied your link or put it in by mistake after the karaoke link or something.  Go back into your control panel & erase what's there & retype.
Author:  knightshow [ Wed Jul 19, 2006 7:47 am ]
I see it when I click on your profile. Neat photo by the way.
PM Phill (aka WEBGURU)
Author:  MorganLeFey [ Wed Jul 19, 2006 5:05 pm ]
I have retyped the url if someone wouldnt mind checking to see it is now operational
Jian thankyou for helping me experiment last nite with pm its much appreciated
thankyou Phil for the compliment
Author:  Jian [ Wed Jul 19, 2006 7:23 pm ]
Your url is still not working.
Author:  MorganLeFey [ Wed Jul 19, 2006 9:25 pm ]
Ok I give up then. I have refreshed my profile twice if it doesnt work I guess its never going to
Thanks for trying Jian I do appreciate your help
Author:  Jian [ Wed Jul 19, 2006 9:33 pm ]
IT works now, I just tried it.
Author:  knightshow [ Thu Jul 20, 2006 8:15 am ]
I think I know what's wrong...
In place of your avatar, it has "profile photo" with a URL. When you click that, it takes you to your PROFILE. I think you've got the WRONG URL. You have the url of your profile, not the picture.
did you put it in the "Avatar control panel" or the "Profile photo control panel"??
What I do is "upload" my photo... have it on your desktop or a folder on your pc, and then do the process of uploading it.
Author:  MorganLeFey [ Thu Jul 20, 2006 8:22 am ]
lol I was trying to have a pic beside my postings like so many others do but I guess it didnt work
I know it is on my profile I guess I should remove it from the avatar thing huh
Author:  Lonman [ Thu Jul 20, 2006 11:32 am ]
To post your pic you need a certain amount of points, then you need to go to the 'forum shop' in the black member area to the left & buy the avitar by your name priveldge with the points you have.  THe more you post, the more points you earn.
Author:  Tony [ Thu Jul 20, 2006 1:44 pm ]
Hm, that is so not like you Lonman, and please refer to the above quote:Follow me here for a second:
OK, got that, last time I looked I had 1718
:O Is this privilege only available to our black members? Guess that's why mine doesn't work either then.
Author:  Lonman [ Thu Jul 20, 2006 2:28 pm ]
Funny!
http://www.karaoke-forum.com/shop.php
Author:  MorganLeFey [ Thu Jul 20, 2006 10:45 pm ]
[schild=17 fontcolor=C0C0C0 shadowcolor=C0C0C0 shieldshadow=1]Grrrrrr No-one tells me when I may have an avitar I just wont have 1!!![/schild]
Author:  MorganLeFey [ Thu Jul 20, 2006 10:48 pm ]
hmmmmm well that worked kinda
[schild=17 fontcolor=8B0000 shadowcolor=C0C0C0 shieldshadow=1]Stamps foot ina redheaded hissy fit[/schild]
Author:  Jian [ Thu Jul 20, 2006 11:26 pm ]
Goto forum shop and buy the privilege to put up the photo using the points you have . you have enough points already. I have check your photo and its of the correct size and resolution, so it should be ok.
Author:  MorganLeFey [ Sat Jul 22, 2006 2:59 am ]
Well I guess the only way to test whether I have done it correctly is to post and see if it shows huh huh?
Thank you once again Sir Jian for galloping to my rescue
Author:  Jian [ Sat Jul 22, 2006 3:09 am ]
Now you may change it but it will cost you some points. I will give you some for you to play around with.
Author:  MorganLeFey [ Sat Jul 22, 2006 3:46 am ]
I am in your debt sir. Now to see if I have made a wise purchase with your donated points
Author:  MorganLeFey [ Sat Jul 22, 2006 3:56 am ]
Ahhhhhhh so now I have a signature, is there any way I may make it larger?
