KARAOKE SCENE MAGAZINE ONLINE! - RSQ MK-22 Key Change Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 4:02 pm
 Post subject: RSQ MK-22 Key Change
PostPosted: Mon Jul 17, 2006 4:57 am
In order to change key, I have to load the song, press pause, press setup, go to Key, adjust it, escape out of Setup, and press play.  The manual said you can do this on the fly.  To me, this is not flying.
Is this the normal routine ?  I would be better off, if that's the case, to try and copy my songs in the correct key.  I was told to separate the lyrics from the audio, change key, and reunite files.
I have a Plextor 760A I just installed in my pc.  What else do I need ?
Sorry, I am just so so with a computer, and have never done this before.
Bernie
 Post subject: Re: RSQ MK-22 Key Change
PostPosted: Mon Jul 17, 2006 9:32 am
Bernie
I use an RSQ MK22 and all you have to do is step the key up or down once you select the track you want.  Which to me is the NORM.
What are you trying to accomplish?   Are you looking to  create a cd with songs for you in YOUR KEY?
PostPosted: Mon Jul 17, 2006 9:53 am
Bernie
Are you trying to use the remote or something?  There is a key changer on the front of the machine & you click it up/down how many you need.  No set-up menu???
PostPosted: Mon Jul 17, 2006 2:02 pm
Thanks guys for setting me straight.  I started with the manual, and nothing described the front panel, and I didn't notice the little symbols were sharps and flates. DUH.
Redfaced, but a happy camper.  You made my day.  Thank you very much.
Bernie
Users browsing this forum: No registered users and 1811 guests
