| Splitter for computer/player and three video outputs https://ksmo.us/forums/viewtopic.php?f=1&t=7114 |
| Author: | magimae [ Sun Jun 18, 2006 8:36 pm ] |
| Post subject: | Splitter for computer/player and three video outputs |
| Author: | Guest [ Sun Jun 18, 2006 11:48 pm ] |
| Post subject: | Re: Splitter for computer/player and three video outputs |
Try MCM Electronics or Radio Shack. I assume they are RCA ends, not Coax. |
| Author: | magimae [ Mon Jun 19, 2006 6:50 am ] |
Thanks for the input. Yes, they are RCA. I was planning on checking at Radio Shack, but thanks for the info on the other place. Hopefully I will find something that will work. I have several video CDGs and would love to be able to use them when I am getting set up, but need them to show on big Plasma screen not small screen on stage.
| Author: | eben [ Mon Jun 19, 2006 12:44 pm ] |
I assume you don't need audio switched so only video. My suggestion is to get a video MUX unit. They will route a video signal from multiple sources to multiple outputs. For example, I have a 4x4 MUX that will feed 4 signals to any or all of the 4 outputs. They can be pricey depends on the level, from like $150 to $1000 but you may be able to find a good solution for about $200. One thing, mine has S-Video input/output. I am not sure how easy it is to find RCA MUX but I am sure they exist. One example of it is here. It's 4x2 but only for S-video and composite video. Again, do some search on Google. I only did a quick check but I am sure you will find what you are looking for. Good luck. |
| Author: | magimae [ Mon Jun 19, 2006 1:01 pm ] |
Many, many thanks for all the help. I think I've got it figured out. I spent the morning on line at Radio Shack & MCM Electronics, then I went to the local Radio Shack. Ours is fairly small, but I think I came up with a solution. I won't know until tomorrow when I reroute everything. If what I got works, I'll let everyone know what my solution was.
| Author: | jamkaraoke [ Mon Jun 19, 2006 1:23 pm ] |
I have a similiar set up and use the following: I take the video outs (RCA) of both my laptop and player into a universal A/B switch ($30) I then take the (1) video out of the A/B swicth and run that into a universal Radio Shack splitter box ( takes 1 input into 4 outputs ) again about $30. Connect the 4 TVs to the splitter box with RCA type cables and you are all set |
