KARAOKE SCENE MAGAZINE ONLINE! - Can't backup Supercore discs? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 8:36 am
PostPosted: Sun Jun 18, 2006 1:38 pm
Sorry if this has already been answered, but I'm making backups of my karaoke discs and out of all of them, my drive would not recognize two sets-- the Supercore 2005 and 2006 collections.  ~30 discs... ouch!
I'm using an NEC 6500a with the latest drivers and even installed ASPI today in an attempt to solve the problem.  No go.  Do I need a different drive (or hopefully, just drivers/firmware)?
Here's my Nero Info:
http://www.josienutter.com/multimedia/k ... foTool.txt
I'm hoping to be able to start running karaoke from my laptop so I can keep my discs in good condition.  I've already had to replace a few.
Josie Nutter
Karaoke Hostess at the Skylark Cafe & Club in Seattle ~ Tues
PostPosted: Sun Jun 18, 2006 3:21 pm
goto www.kjamp.com and download KjripNzip which is a free program. I know it works with nec drives. CDrwin will also give you their aspi drivers if you want to use them.
you can also try www.goldenhawk.com and get cdrwin as they list your drive as compatable. after that you need cdgautoname to name the files then you need MP3+GToolZ to convert it to mp3+G.
PostPosted: Mon Jun 19, 2006 10:52 am
Awesome, thanks for the advice-- I will check those out!
Josie Nutter
PostPosted: Mon Jun 19, 2006 10:34 pm
I use audiograbber which works well, even on the Top Tunes discs that have the "protection" built in that defeats the CDR WIN program.
Spreading the karaoke gospel
PostPosted: Tue Jun 20, 2006 4:46 am
Agree! Here's the link:
http://www.audiograbber.com-us.net/download.html
PostPosted: Tue Jun 20, 2006 11:19 am
I use Microstudio when i run into copy protected stuff that cdrwin can't handle. Adds renaming to bin as a step but works perfectly everytime.  Always liked micrstudio over crwin anyway as i can test the files before conversion to even dcide whether it is worth converting.
PostPosted: Tue Jun 20, 2006 11:37 am
None of them were helping, so I tried going from the last disc instead of the first.  Power CD+G Burner is not having any problems.
I think it might be something with the first (or first few?) discs in the 2005 collection.  When I put the disc into my laptop, the DVD drive doesn't spin up like it does with the others.  I think that's the main problem.  I'm going to try reading from another drive ... or maybe the disc(s) itself is bad...
Josie Nutter
PostPosted: Tue Jun 20, 2006 5:19 pm
Ultimately, only the 1st disc was not recognizable... not sure what that's all about but I will check to see if the normal player will accept it tonight.
Josie Nutter
Users browsing this forum: No registered users and 2730 guests
