I think I messed up....
https://ksmo.us/forums/viewtopic.php?f=1&t=6981
Author:  Blackrose [ Sun May 28, 2006 5:53 pm ]
Post subject:  I think I messed up....
I am ripping my cdg's to my pc using audiograbber. I am doing 192k so they will sound good, but noticed I ripped them all clicking on make cdg + compression. I am unsure if this is the right one to click, because they work and everything, but they do not say they are mp3's. Did I do this right? Thank you.
Author:  knightshow [ Sun May 28, 2006 8:33 pm ]
Post subject:  Re: I think I messed up....
yes, that's the mp3 compression.
However, what encoder are you using?  Click on the MP3 tab, that goes to the settings.
Author:  DannyG2006 [ Sun May 28, 2006 10:19 pm ]
Knightshow is right.
depending on if you have an mp3 encoder loaded on your system, either lame or blade, you should be getting cdg + MP3 files out of the process.
There are other compressions suc as wma, ogg and the like.
if you see a cdg file and a wma file then it encoded in windows media file format.
Author:  Blackrose [ Mon May 29, 2006 2:10 pm ]
I am using Lame as the encoder, I will have to check again if it is Mp3 or not, They just dont seem to be coming out good, even at 192k. They crackle and such when I am playing them off the pc.
Author:  knightshow [ Tue May 30, 2006 5:15 am ]
what are you using for your .mp3 player, Blackrose?
I personally like winamp, but others I know use media player, jukebox, etc.
Author:  Blackrose [ Wed May 31, 2006 8:26 pm ]
I am using Winamp, with the cdg plugin and it works ok. I am thinking of using some kind of hoster other than winamp for karaoke.
Author:  twansenne [ Thu Jun 01, 2006 6:20 am ]
Perhaps try ripping them at a slower rate, or maybe your pc speakers aren't that great?
Encoding at 192 should provide a quality sound.
Author:  Blackrose [ Thu Jun 01, 2006 5:01 pm ]
I am using my new yamaha pa system to play everything.
Author:  twansenne [ Fri Jun 02, 2006 8:31 am ]
How do you have your sound from the PC to the mixer hooked up?
It's a long shot, but the PC may ben outputting at to high of a level, and the PA system is clipping the sound.
Author:  Blackrose [ Fri Jun 02, 2006 10:16 pm ]
I have a sb audigy 5.1 xgamer sound card connected to the mixer via 1/8" cable to rca.
