KARAOKE SCENE MAGAZINE ONLINE! - Mixer problem Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 4:53 am
 Post subject: Mixer problem
PostPosted: Mon Apr 24, 2006 9:47 pm
What would cause the right channel output to be fine, and the left to be at a very reduced volume or not at all?   I have a Mackie and a Pee Vee doing the exact same thing.    Two different systems.    Even does it if I just set up the mixer in the cellar to totally different stuff.    A few years ago I bought the Mackie to replace the PV.    Now the Mackie is doing it.
 Post subject: Re: Mixer problem
PostPosted: Tue Apr 25, 2006 3:51 am
What else is in the signal chain?  Are you using the same equipment?  Cords?
PostPosted: Tue Apr 25, 2006 10:56 am
Been Liked: 53 times
OMG....a Mackie & PV that went bad.....LOL (inside joke)
Anywho....
You don't happen to have a PAN knob that got bumped?
OR perhaps an Input Level or Gain button got switched?
Just a cople stabbs in the dark
PostPosted: Tue Apr 25, 2006 1:10 pm
Bigdog
What is the input source ?  CDG PLAYER  / PC  / other
Are you inputing thru the CD TAPE RCA INPUTS OR using a stereo channel strip?
Little more info will yield a lot more advice  :D
PostPosted: Wed Apr 26, 2006 2:02 am
Yeah that's what I thought too.     Hooked them both straight out to a powered speaker.    Same input player.     Turned every knob and pushed every button.    Today after some contact cleaner spraying , the left side of the Mackie is now full volume and the right is only half.   It switched sides.     Talked to some techs today that weren't much help, the one told me it needs serviced.     Whoa, I bet he's the smartest one they have.   I couldn't have thought of that in a million years.
Users browsing this forum: No registered users and 2336 guests
