KARAOKE SCENE MAGAZINE ONLINE! - trouble with mp3+g toolz Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Wed Nov 04, 2026 7:57 pm
 Post subject: trouble with mp3+g toolz
PostPosted: Tue Apr 04, 2006 3:20 pm
is there another program i could use. every time i use mp3+g tools it locks up my computer
PostPosted: Tue Apr 04, 2006 5:51 pm
you might try a non.net version of mp3toolz... do a google search, you may find someone with the pure program. look for "toolz.exe"
PostPosted: Tue Apr 04, 2006 8:03 pm
Been Liked: 53 times
I had problems with the new version of Toolzs, wen back to older version and all was fine.
PostPosted: Wed Apr 05, 2006 12:56 am
Look for an old 2.0 era version. It will work alot better.
PostPosted: Wed Apr 05, 2006 3:59 am
As long as you stay with .net 1.1, mp3+g toolz work perfectly fine.
Money is better than poverty, if only for financial reasons.
PostPosted: Wed Apr 05, 2006 9:39 am
I found one called Troubador (sic?) that seems to work well-- but I think it depends on toolz though-- I think they have an add-on for zip files with mp3+g stuff in it.
PostPosted: Wed Apr 05, 2006 2:04 pm
If it's a newer version of mp3+g toolz you have to install dotnetfx.exe to make it work properly.
ROBDOG *WOOF WOOF*
PostPosted: Fri Apr 07, 2006 11:49 pm
Blade encoder will change wav to mp3 at 128 if that's what you are trying to do, it's also a plugin for total recorder and will record any length of songs. Also nero cd burner v5.5 has a thing in the "ahead" folder that is a wav editor, it will add effects and do eq quite nicely as well as cut the click track or silence from the ends of files if you are using midi files for backing tacks. It also does fadein fade out.
hope this helps you a bit.
L.
PostPosted: Sat Apr 08, 2006 10:32 am
not even in the same ballpark...
Users browsing this forum: No registered users and 1624 guests
