[ 9 posts ] |
chuckman45
Posted: Tue Apr 04, 2006 3:20 pm |
| newbie |
Joined: Thu Mar 10, 2005 6:56 am Posts: 2 Been Liked: 0 time
is there another program i could use. every time i use mp3+g tools it locks up my computer
knightshow
Posted: Tue Apr 04, 2006 5:51 pm |
you might try a non.net version of mp3toolz... do a google search, you may find someone with the pure program. look for "toolz.exe"
twansenne
Posted: Tue Apr 04, 2006 8:03 pm |
I had problems with the new version of Toolzs, wen back to older version and all was fine.
lyquiddye
Posted: Wed Apr 05, 2006 12:56 am |
Look for an old 2.0 era version. It will work alot better.
ShyGuy
Posted: Wed Apr 05, 2006 3:59 am |
Joined: Wed Feb 08, 2006 2:36 pm Posts: 177 Location: Miserable Town Been Liked: 0 time
As long as you stay with .net 1.1, mp3+g toolz work perfectly fine.
_________________ Money is better than poverty, if only for financial reasons.
UncleFire
Posted: Wed Apr 05, 2006 9:39 am |
Joined: Sat Dec 03, 2005 10:09 am Posts: 102 Location: Phoenix Been Liked: 0 time
I found one called Troubador (sic?) that seems to work well-- but I think it depends on toolz though-- I think they have an add-on for zip files with mp3+g stuff in it.
robdogkaraoke
Posted: Wed Apr 05, 2006 2:04 pm |
| Advanced Poster |
Joined: Mon Mar 03, 2003 8:46 pm Posts: 472 Location: MONTREAL, QUEBEC, CANADA Been Liked: 0 time
If it's a newer version of mp3+g toolz you have to install dotnetfx.exe to make it work properly.
_________________ ROBDOG *WOOF WOOF*
larrysmusic
Posted: Fri Apr 07, 2006 11:49 pm |
Joined: Fri Mar 31, 2006 5:35 pm Posts: 29 Images: 0 Location: Calgary Alberta Been Liked: 0 time
Blade encoder will change wav to mp3 at 128 if that's what you are trying to do, it's also a plugin for total recorder and will record any length of songs. Also nero cd burner v5.5 has a thing in the "ahead" folder that is a wav editor, it will add effects and do eq quite nicely as well as cut the click track or silence from the ends of files if you are using midi files for backing tacks. It also does fadein fade out.
hope this helps you a bit.
L.
Tigrr27
Posted: Sat Apr 08, 2006 10:32 am |
not even in the same ballpark...
[ 9 posts ] |
Users browsing this forum: No registered users and 1620 guests |
