KARAOKE SCENE MAGAZINE ONLINE! - Burner not Found Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 10:30 pm
 Post subject: Burner not Found
PostPosted: Wed Mar 15, 2006 2:03 pm
CDR WIN no longer finds my plextor burner.
It says no cdrom recording device was found on the SCSI or IDE bus.
I have been trying everything I can think of for the last 2 days. I have tried every version of CDR WIN on their site and none work.
Every other buring program I have works just fine, but I really want to burn a karaoke cd to go out and sing I haven't gone out to sing on a night off in over a year.
 Post subject: Re: Burner not Found
PostPosted: Wed Mar 15, 2006 2:22 pm
I would assume that no other programs see it either.
This might be reaching but do you have your Plextor set for cable select slave or master?
Try the Plextor in another pc and see what happens.
Double check the bios and see what it's set for.
PostPosted: Wed Mar 15, 2006 2:36 pm
I had the same problem when I upgraded to my Plextor 716A, then after downloading the Plex upgrades and upgrading to CDRWin 4.x it worked. Hope that helps.
If you use other program e.g. Hoster, does that still recognise your drive?
Money is better than poverty, if only for financial reasons.
PostPosted: Wed Mar 15, 2006 3:15 pm
Had this happen once....I lost both CD's and the floppy...swapping drives would not fix it, reinstalling drivers would not fix it....I even replaced the motherboard....nothing would fix it....
Turned out the wife was using kazza and she had downloaded a bad virus embedded in a song file....I had to install an additional new HDD and a new OS and then recover what was left of our undamaged files from the old drive....Then reformat the old drive.
If you have mp3/video files from other than legal sources, then you need to segregate them and scan each with a very good virus program before you play them.
...and no, i ain't saying you posess illegal files, i'm just saying it might be a virus.
PostPosted: Wed Mar 15, 2006 3:59 pm
I would update your ASPI Drivers for both Plextor and Your Program. Restart then check again.
Did you buy a new plextor drive? or Upgrade the CDRWin recently to bring about this change or did it just happen by itself?
Did you recently install or download a burning program? One time I downloaded Roxio (burning program) and it did similar things to what you are experiencing. I un-installed the program and rebooted and everything was just fine.
FlipSide Karaoke
Scott
PostPosted: Wed Mar 15, 2006 4:22 pm
Yep, that too...I once installed a Nero DVD burning program that caused me to lose my drives.
PostPosted: Wed Mar 15, 2006 6:45 pm
Im psychic but not that good Need some info to give an answer
  How old is it? has it see a lot of use?
  When you put in a cd does the light turn amber then green in a short amount of time (reading index)?
  Has it been having trouble reading cd's or the index?
  Have you reseated the ide plugs?  Is it on the same ide with hard drive? slave?
 Go into tools in cdrwin are you using cdrwin aspi or windows?
  With the door open look in with a flashlight see if there is a bunch of junk (hairs etc)
  I have cleaned the optics on a lot of plextors but they are very delicate.
  ITs not  unusual for one to fail without having minor problems first (  have gone thru about 4 or 5).....
PostPosted: Thu Mar 16, 2006 5:24 am
ASPI drivers must be updated find them here:
http://www.adaptec.com/worldwide/suppor ... PI+Package
Adaptec  Windows ASPI Package  Downloads
ROBDOG *WOOF WOOF*
PostPosted: Fri Mar 17, 2006 1:57 am
It Happened when I got a new version of Nero.
I had to use a odd version of CDR Win I had to get the Unicode Version for some reason.
PostPosted: Fri Mar 17, 2006 4:03 am
NERO!.....Forget it, that was another time I had to reformat...hope you have better luck than me, tho...If you fix it, come back and tell us what you did.
Users browsing this forum: No registered users and 2016 guests
