KARAOKE SCENE MAGAZINE ONLINE! - dvd recorder Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 10:30 pm
 Post subject: dvd recorder
PostPosted: Sun Mar 12, 2006 10:04 pm
Hi all!!
   I just got a dvd recorder and want to record live through my mixer wich is a ub 1622fx-pro Behringer for now. And was wondering the easiest way to do it. I got 2 rca ti 1/4 inch wires just need to know where to plug into the board to pick up the live signal (the same 1 that comes out of the mains) without compromising my setup.
ROBDOG *WOOF WOOF*
 Post subject: Re: dvd recorder
PostPosted: Mon Mar 13, 2006 6:23 am
Why not just use the headphone output? Then you can regulate the recording level as well. Personally I use the Sub outputs as recording inputs.
Money is better than poverty, if only for financial reasons.
PostPosted: Mon Mar 13, 2006 8:07 am
Looks like you have 1 set of R/L RCA Outs at the top of the board. You could go RCA out of the board to RCA in on the DVD Recorder.
FlipSide Karaoke
Scott
PostPosted: Mon Mar 13, 2006 8:10 am
robdog, on the top of the mixer is "Tape In and Tape Out".... us the tape out.
PostPosted: Mon Mar 13, 2006 1:23 pm
The tape out didn't seem to work looking for another option . Do you think the main 1/4 inch out would work without affecting the sound from my xlr main mix?  Or the control room out?
ROBDOG *WOOF WOOF*
PostPosted: Mon Mar 13, 2006 2:41 pm
robdogkaraoke, did you try this?
PostPosted: Mon Mar 13, 2006 3:14 pm
I personally use the control room output for my recording.  If you use the tape out the level is way to low, the headphone out will work as well but if you actually use headphones then your kinda outta luck with that one.
PostPosted: Wed Mar 15, 2006 4:33 pm
Thanks pkircher  :hi5:  Control room out worked great the sound is awesome on the recordings. :worship:
ROBDOG *WOOF WOOF*
PostPosted: Thu Mar 16, 2006 12:13 am
Yeah I've been doing that for about a year now.  I'm glad it works for you as well.  Good Luck with it.
Users browsing this forum: No registered users and 2022 guests
