KARAOKE SCENE MAGAZINE ONLINE! - Using PC/Laptop for your karaoke show? How to record singers? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 8:46 pm
PostPosted: Thu Mar 02, 2006 3:24 pm
I would like to be able to record my singer's performance.  Can I just use a software program like total recorder or something and plug directly into the mic input to the mixer out or something?  Please let me know what ya'll are doing.  I would like to be able to make a burned CD on the spot for people as well.  Thanks, D.J.
PostPosted: Thu Mar 02, 2006 4:05 pm
depends on how you're mixing your music!
I run my music from the computer to a mixer, to a mixer/amp. That amp has a pre-out, and that includes the mics... total speaker sound. From that I can pull back into the computer. I'd recommend the USB Soundblaster MP3+ device over the "mic in". The USB Numark mixer also has a usb back out to the computer I'm going to experiment with this weekend on recording singers.
PostPosted: Thu Mar 02, 2006 6:56 pm
An easy way to record your customers is with a DVD recorder with built in hard drive there are a lot available. You just set it up with the tape out rca plugs on your board and record live from your mixer and burn them a dvd audio copy if they want 1. Simple.
ROBDOG *WOOF WOOF*
PostPosted: Thu Mar 02, 2006 7:06 pm
http://www.m-audio.com/products/en_us/MicroTrack-main.html
Easy to use and porable
PostPosted: Thu Mar 02, 2006 7:14 pm
you can't rip a disk with that on the spot but it is a great little machine!
ROBDOG *WOOF WOOF*
PostPosted: Thu Mar 02, 2006 7:51 pm
Been Liked: 15 times
Most karaoke software will record your singer's performance.  Use tape out on your mixer into line in on the sound card and you're good to go.
PostPosted: Fri Mar 10, 2006 12:40 pm
thank you for all the great info.  :-)
PostPosted: Sat Mar 11, 2006 12:45 pm
Online
Only karaoke prog I know have that has its own recording is RoxBox and Sack-onuts.
If any have added it it has been because Of RoxBox offering it.
If you're cd based it only menas carrying your computer or having a cd recorder as an extra piece of equipment.
Users browsing this forum: DannyG2006 and 1872 guests
