KARAOKE SCENE MAGAZINE ONLINE! - Anyone know anything about Winamp? Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 7:53 pm
PostPosted: Tue Feb 21, 2006 10:11 pm
Been Liked: 4 times
Not too long ago, I "heard" someone on line say something about making accompaniment tracks using Winamp.   Has anyone tried this?  What are your thoughts about it?  Thanks!
I love being a mom!
PostPosted: Tue Feb 21, 2006 10:50 pm
I assume you start with a ripped song that have vox in it. Yes you can remove the vox with Winamp. You just need to download the plugin 'Nullsoft Signal Processing Studio DSP from here http://www.winamp.com/plugins/
But you will not get good result, but its free. Just give it a try.
edit: you may already have the plugin , check by going Option>Visualization>Select plugin> DSP effect
PostPosted: Wed Feb 22, 2006 9:31 pm
I used winamp for awhile but I heard a lot of bad reports regarding viruses.  All though I never got a virus I got a little gun shy.  I heard good reports about a site called LIMEWIRE so I switched and DL hundreds of songs from it.  You can get it free but if you want a bit more from it you can get the pro version.  I got the pro version and after did'nt think it was worth the bother.  Check it out as it don't cost anything and its very safe.
Regards Mikey
PostPosted: Wed Feb 22, 2006 9:59 pm
The post is about WinAmp not WInMX.  I use a front end and winamp for my karaoke & DJ gigs without a problem.
I have made karaoke songs using MTU's Vogone and Karaoke Home Producer.
PostPosted: Thu Feb 23, 2006 9:43 am
I use winamp for a stand alone player. PC is NOT hooked up to the internet. When I rip my tracks, I use Audiograbber with the LAME_ENC.dll as my compression technique.
there is no virus issue with a stand alone unit. I use winamp on my home pc and I don't THINK I've ever had a virus issue due to WINAMP... but I'll be honest, stuff has leaked in, and I'm unsure if it's due to the antivirus I use or just normal stuff hacking it's way in. I'm not the pc guru that some folks are... so I can't just discount that virus issue for a pc hooked up to the net.
Users browsing this forum: No registered users and 1791 guests
