KARAOKE SCENE MAGAZINE ONLINE! - Need a little help with my DBX 266xl Public Forums Karaoke Discussions Karaoke Scene's Karaoke Forums Home | Contact Us | Site Map
It is currently Tue Nov 03, 2026 8:51 am
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Sat Feb 11, 2006 6:54 pm
Starting to KJ. So, I invested in a DBX 266xl, Numark CDN25, and VocoPro KJ-7800.  I'm running my 266xl (in stereo mode) out of my mixer into power speakers. Can somebody help me with "a starting point" with the knobs.  I know, I will need to tweak them.  But I need a starting template first.  Hell, if you could just take a picture of your 266xl with the knob settings.  LOL   I never really push my speakers because I don't have to.  Power Mackie tops and subs!  But I do not want any singers damaging my speakers.
PostPosted: Sat Feb 11, 2006 7:35 pm
K first off get it out from in between the mixer & powered speakers - unless your goal is JUST to compress the final output.  Being set up this way will give speaker protection, but it will also compress everything including the music if someone screams into the mic which usually isn't the ultimate goal.  If you want vocal compression, plug your mics into the dbx then out into the mixer.  This will compress the mics only while leaving the music intact.  set it in dual mono mode so 2 mics will have compression.
Set the ratio at around 4:1 to start, there is an "auto" switch, engage it, this will automatically set the attack & release.  Then the output to a little over "0".  The output may need to go a little higher, but then you do your regular mic adjustments at the mixer.
PostPosted: Sat Feb 11, 2006 9:14 pm
Lonman is most correct, use it only on your mics...There is no need to limit properly setup powered speakers.
Also remember that whenever you EQ the mics on their strip it can change the gain into the compressor. You are smart to use one...It really helps level out the screamers and mic slappers/droppers.
I never tried a comp with an auto feature...How well does that work, Lonman?. I'm considering replacing my 3630. How does the DBX compare? My Art Pro channel has a comp built in, but I only plan to use it when recording. If the auto feature works well, I'll replace the 3630 so I'm not riding the comp gains so much between singers.
PostPosted: Sun Feb 12, 2006 2:25 am
If you know what you're doing, manually setting the attack & release will be better, however I go on the premise most don't know how to set them up properly so the auto feature will usually suffice - and for the most part te auto setting will do just fine by itself.  I replaced my 2 Alesis 3630 (it sucked), with a couple Symetrix 501, if I were going to replace with dbx my first choice (budget allowing) would be the 160A, however the 166XL is also a very good alternative live - plus it's a dual channel & more budget friendly.  The 266XL is a nice unit, but it doesn't have the limiter that's built into the 166XL which I feel is crucial for controlling those "screamers".
PostPosted: Sun Feb 12, 2006 2:40 pm
Thanks Lonman,
 Couple more questions.
1. "Expander/Gate" has two knobs: Threshold and Ratio.  Where should those knobs be turn?
2.  On The Compressor, where should the Threshold knob be turn? Also should the Overeasy button be turn on?
All of your expertise is appreciated!! THANKS AGAIN
PostPosted: Sun Feb 12, 2006 3:18 pm
rlleon09 @ Sun Feb 12, 2006 2:40 pm wrote:
Thanks Lonman,
Don't worry about the expander gate, not that useful on multiple different singers so keep them off.
On the compressor, the threshold I would run anywhere from 12:00 - 2:00.  The 12:00 setting will compress more - this know does coincide directly with the ratio knob.  The overeasy button should be turned on.
PostPosted: Sun Feb 12, 2006 3:41 pm
Lonman as usual youn are giving good advise The only thing I can add in the excitement of the situation unless a singer is screaming I am comfortable with the fact that if only one or 2 red lights are blinking I am close to to the right settings... Do you find this also?
PostPosted: Sun Feb 12, 2006 7:50 pm
I do find that!
PostPosted: Mon Feb 13, 2006 7:02 pm
Took your advice!  Moved the 266xl.   Using it just for vocals.
PostPosted: Mon Feb 13, 2006 7:32 pm
Hows it working?
PostPosted: Wed Feb 15, 2006 2:47 pm
I had a gig last night set it up (vocal to 266lx to mixer).  Huge hum sound?  Switch it back (Mixer to 266xl to speakers). NO hum sound!  What gives?
Need your help..  thanks
PostPosted: Thu Feb 16, 2006 3:54 pm
There is a big difference tween low-z mic input and line level input from mixer, so make certain your input gain on the DBX is configured properly when placed ahead of mixer....If you had HUM, you had a ground loop, if it was HISS, you had poor gain structure.
Do you use XLR or 1/4" when patching from the mixer?
PostPosted: Thu Feb 16, 2006 4:25 pm
Compressor 101
Compressor 101
PostPosted: Thu Feb 16, 2006 4:41 pm
ShyGuy @ Thu Feb 16, 2006 6:25 pm wrote:
....AND?
You posted links to discussions in a guitar forum related to use of compressors on guitar....Where in those links does it discuss the use of a compressor in a mic signal chain?...Or in any way relate to his question/problem?
Please explain it there is any info in those links related to this thread.
PostPosted: Thu Feb 16, 2006 5:40 pm
Been Liked: 34 times
I'm using the same DBX model and also had this hum problem that came from this device, need to remember what I did??? I'm now using the best cables available and all balanced when possible, also, get yourself a good electric space bar, APC makes some very good models.
PostPosted: Thu Feb 16, 2006 5:53 pm
I'm using XLR.  I don't think it is a ground loop. That was my first thought.  I may be wrong but if it was a ground loop it should have still hummed when I switch it back (mixer/DBX/speakers).
PostPosted: Thu Feb 16, 2006 5:56 pm
Oh allmighty Keith, first of all, please read the threads completely, then throw your weight around. I added this for general information regarding compressors. But, then again, seeing that it did not include any information regarding your blown-up ego, or any of your sexual references, you probably could not relate to the content.
A compressor narrows (compresses) the dynamic range. It normalizes volume, not "tone" per se.
Signals hitting the compressor at levels exceeding a specified threshold have their volume reduced by a specified ratio. As the signal level comes back toward the threshold, the compressor releases its hold allowing the signal to decay naturally.
Often, the threshhold and ratio are user settable. Some compressors allow the user to specify how quickly the volume is compressed, as well as how quickly it is released.
Imposing very high ratios of compression, where the volume cannot exceed the threshold and the compression kicks in very quickly, is known as "limiting." Thus, you'll often see compressors called "compressor/limiters".
By compressing the signal, we increase the amount of time that its volume stays within a narrowed range by never letting it get above the threshhold; thus, we are increasing sustain. Also, by limiting the dynamic range and incorporating some boost to the signal, we can increase the overall level of volume before distortion kicks in. This can be handy for playing clean and still cutting through a mix.
Conversely, an "expander" increases the loudness of a signal approaching a given threshold by specified ratio. In expansion, as the signal decays, its volume is boosted back toward the threshold until it has decayed enough that the expander lets it die or kills it. Extreme "downward" expander settings, which very quickly cut signals that fall below a specified threshold, are called "gates." This is how "noise gates" work.
An Expander is used as a noise eliminator. The threshold allows one to set a spot below which the signal is expanded downward to a certain or variable ratio. The process is actually downward noise expansion, or variable soft-edged gating. Typically the threshold is set somewhere near the point the natural decay of the incoming notes is beginning to blend into hiss (the noise floor).
As far as the Behringer settings go, do what sounds best for the incoming program material. I assume that fast and slow are release time, but not knowing the Autocom firsthand couldn't advise you what their times are like, and whether they were well chosen. But your ear can: just listen for side-effects and pick the one that is the best compromise of cleaning up noise, and affecting the envelope of the bass notes. On similar equipment I have used, the fast settings often are used for single instruments, and the slower settings for a [sub]group or an entire mix.
In the Compressor section the knob you must be asking about is also Threshold; you indeed set this where you want compression to kick in. If you are mainly wanting to control peaks, set it high and use a high ratio. If you want a subtle compression on almost all notes, set a lower threshold and milder ratio.
Again, the key is to experiment, and hopefully you will get to grow your ears in the bargain. Look around for recording magazines and white papers on audio sites, etc. Even after lots of reading, it still comes down to taking what you understand now, and then listening. That's paramount.
Use the exciter with that in mind, attempting to not go beyond replacing some high end that might have been precieved as missing, without getting into ear-fatiguing, unnatural amounts, unless you of course want to use an artificial sheen occasionally as an effect.
PostPosted: Thu Feb 16, 2006 6:01 pm
Not always, certain things in certain order can produce all kinds of noise, then hooked up another way may not.  Quick way to test is have your mixer & compresor hooked up for vocals & have them plugged into a power strip with a ground lift adapter (3 prong to 2 prong - make sure the metal tab isn't touching the screw).  If there is no more hum then you have a ground loop - however DO NOT leave it hooked up that way, that is for test only.
PostPosted: Thu Feb 16, 2006 6:15 pm
I'll have to try that out Lonman.
PostPosted: Thu Feb 16, 2006 9:57 pm
I hesitate to try to give tech advise here anymore More information is needed ( vague questions only gets vague answers and on here 40 blind guesses and arguments) You say you are using xlr The mics should be plugged into the xlr mic inputs and the 266xl routed from and returned to to the inserts. It sound like you might be running a line level out from the 266xl into the pre which wont work and might give a hum or buzz ... Also  I run my 266xl at -10 db on the back (I still dont like the pres in this dfx12) It says in the decription that mixer has inserts..  Is that the way you are hooked up?
Users browsing this forum: No registered users and 2117 guests
